PARAM, HFREQFL
Bulk Data Entry Excludes modes with frequencies greater than HFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
| Parameter | Values | Description |
| HFREQFL | <Real>
(Hertz) Default = None Default: If PARAM, HFREQFL is input without specifying a value, the solution runs into an error. |
Modes with frequencies greater than HFREQFL are not used in Coupled Modal Frequency Response Analysis. HFREQFL can be used to remove Rigid Body Modes from the Modal Space. |
- Modes that are eliminated by PARAM, HFREQFL will display an "H" next to the mode number.
