PARAM, KISSSOFT
Bulk Data Entry Controls the creation of the condensed stiffness matrix in an ASCII file to be used by the KISSsoft program.
| Parameter | Values | Description |
| KISSSOFT | <YES, NO> |
- The CMSMETH Bulk Data Entry with METHOD field set to GUYAN should be used with PARAM,KISSSOFT,YES.
