PARAM, MATFREQ
Bulk Data Entry Turns off any frequency-dependent materials (MATF#) that are present in the model.
Parameter Values Description
MATFREQ <ON, OFF>
ON (Default)
Frequency-dependent materials are not turned off.
OFF
This is used to turn off any frequency-dependent materials (MATF#) that are present in the model. They are ignored during the run and are not printed in the list of material data in the .out file.
