PARAM, SUBRESVC
Bulk Data Entry Used to control whether residual vector generation is subcase-dependent when the AMSES eigensolver is used.
Parameter Values Description
SUBRESVC <YES, NO>
Default = NO
  1. The default is NO when the parameter is not present in the deck.
  2. If specified in the input deck without a value, an error is issued.
YES
Load vectors from each subcase are considered separately for the corresponding subcases for residual vector calculation during the AMSES eigensolution. The residual vector generation is subcase-dependent for AMSES.
NO
During residual vector calculation with AMSES, the load vectors from all subcases are considered.
  1. For more information, refer to AMSES (Automatic Multi-level Sub-structuring Eigensolver Solution) in the User Guide.
