DOPTPRM, TOPDV
Bulk Data Entry Activates an alternative method for the generation of topology and level-set design variables.
| Parameter | Values | Description |
| TOPDV | ALTER
Default = If this parameter is not specified in the input file, then the alternate method is not activated. |
- For additional information, refer to Advanced Restart for Topology and Level-set Optimization.
