DOPTPRM, SHAPEOPT
Bulk Data Entry Defines an optional parameter to select an alternative shape optimization algorithm.
| Parameter | Values | Description |
| SHAPEOPT | Integer = 1 or 2 | This algorithm can be
selected when non-moving shapes are encountered in the optimization.
If discrete design variables are present, it is recommended to use this parameter along with design optimization parameter, DDVOPT=2. |
