DOPTPRM, APPROX
Bulk Data Entry Switch to select the approximation type for stress/strain responses of shells, composites and 1D elements.
| Parameter | Values | Description |
| APPROX | Static
Optimization <FULL, REDUCED> Dynamic Optimization <FULL, HIGH, MEDIUM, LOW> Default = FULL (except for Random Response Fatigue Optimization, where default is LOW). |
For Static Optimization,
available options for response approximation are
REDUCED and FULL (these
options are applicable for any force-based responses for shells,
composites and 1D elements. For example, stress/strain responses):
For Frequency Response Optimization and Random Response
Fatigue Optimization, available options for response
approximation are HIGH, MED,
LOW, and FULL (these
options are applicable to responses in dynamic optimization
which are combinations or functions of values over a range of
frequencies. 1):
This framework allows response approximation (constant response approximation) non-peak responses across a frequency range. Lower quality implies lower memory/computational requirements, while higher quality implies higher run times and memory usage compared to the other options. |
- Approximation for Dynamic Optimization via HIGH, MED, and LOW options is currently supported only for RTYPE=FRPRES, FRDISP, FRVELO, FRACCL, FRERP, DAMAGE, and LIFE response types on DRESP1 entry. For effective usage of these options, multiple frequencies or a frequency range should be available for the frequency-based response and the response should be a function or combination of values over a range of frequencies; for example, if the ATTB field is set to RMS, SUM, and so on. Therefore, for DAMAGE and LIFE responses, these options are only applicable for Random Response Fatigue Optimization.
