.mapdsp file
The .mapdsp file is an OptiStruct ASCII format results file.
File Creation
This file is created when PARAM, LCLGRDST, <GRID_SETID> is defined in the local model during a submodeling job, where GRID_SETID is a set of nodes defined in the local model.
File Contents
This file contains the mapping information of each local node to the global nodes, for all local nodes in the grid set.
File Format
Subcase ID | <Subcase_ID> |
N_G1 | Global nodes used in mapping for local node | L1_ID | |||||
G1_ID | G2_ID | etc. | GN i_ID | etc. | GN G_ID |
- Subcase_ID : Subcase ID of the local model
- N_Gi : Number of global nodes mapped to the ith local node
- Li_ID : ID of the local node
- GN i_ID : ID of the ith global node
Subcase ID 2005
3 Global nodes used in mapping for local node 61040
1176 1177 1197
3 Global nodes used in mapping for local node 61041
1176 1177 1197
3 Global nodes used in mapping for local node 61042
1176 1177 1197
4 Global nodes used in mapping for local node 61043
1156 1157 1177 1178
- For more information, refer to Global-Local Analysis (Submodeling) in the User Guide.
