The .spcf file is an OptiStructASCII format results file.
File Creation
Creation of this file is controlled by the SPCFORCES I/O Option.
File Contents
Result
Single-point force of
constraint
constraints for linear static analysis, nonlinear static analysis,
and frequency response analysis.
File Format
The SPC reaction force file has the following format:
For each iteration, the following header is
used:
iter
Iteration
Numlds
Data
iter
Keyword denoting the beginning of a new iteration.
Iteration
The iteration number.
Numlds
The number of subcases for which this output is created.
Each iteration section is divided up by subcase.
Output for each subcase starts with a line in the following
format:
Id
Number_of_nodes
Frequency
SPCF:Spc_id(Datatype)
subcase_label
Data
Id
The output identification number for the subcase. This is not the same
as the subcase ID used in the input data
Number_of_nodes
The number of nodes for which this output is requested.
Frequency
Is 1.0 for static analysis.
SPCF
Keyword declaring SPC-force information
Spc_id
The SID for SPC's referenced by this subcase.
Datatype
Keyword indicating the type of subcase involved.
(LOAD) declares data is for a linear static subcase.
SPC-force information is then provided, for each
node, in the following format:
Node_id or
SUM-#
x-force
y-force
z-force
x-moment
y-moment
z-moment
Data
Node_id
The node identification number.
SUM-#
This consists of SUM-ALL, SUM-ALL-B, and SUM-ALL-U. 2
x-force
The x-translational component of the force at the node.
y-force
The y-translational component of the force at the node.
z-force
The z-translational component of the force at the node.
x-moment
The x-rotational component of the force at the node.
y-moment
The y-rotational component of the force at the node.
z-moment
The z-rotational component of the force at the node.
In addition to the above values:
The I/O Option Previously Supported Results controls
the frequency of output for analytical results during an optimization.
SUM-ALL-B is the sum of SPCF results in
the basic coordinate system, and SUM-ALL-U is the sum of SPCF results in the
user-defined coordinate system via SPCFORCE(CID=ID), where
ID is the user-defined coordinate system (via for
example, CORD1R). Figure 1 showcases how the output at
the end of the .spcf file looks for the case where such
user-defined coordinate system based output is requested using
SPCFORCE(CID=12).
