.HM.elcheck.cmf file
The .HM.elcheck.cmf file is a HyperMesh command file.
File Creation
The file is created when an element quality check is performed.
File Contents
This file contains results from the following tests:
- Element quality tests using ELEMQUAL entry and PARAM, CHECKEL.
- Incorrectly formed CFAST and CWELD elements.
- CBUSH or CELAS elements with excessive stiffness values (stiffness values set on PBUSH, PELAS, PARAM, BUSHSTIF and PARAM, ELASSTIF).
- If SYSSETTING(ELMERRCMF=YES) is present, element quality checks are automatically turned on. Along with the regular element quality errors, the elements which failed due to negative Jacobian and Collapsed grids are also printed to the HM.elcheck.cmf file.
When executed in HyperMesh, the .HM.elcheck.cmf file organizes all elements into separate sets depending on which quality check they fail. One set is created for each failed quality check. This helps you to visualize results by finding (displaying) elements by set.
- Ensure the corresponding model is loaded in HyperMesh when executing the command file.
