.trf file
An ASCII format results file which contains Bulk Data of loads from Aeroelastic Analysis results.
File Creation
This file is always created when the TRIMF I/O Entry is specified for an Aeroelastic Trim analysis run.
File Contents
This file provides the output of trim loads from a static Aeroelastic Analysis as FORCE/MOMENT Bulk Data Entries.
File Format
The file contains trim loads from a static aeroelastic analysis as FORCE/MOMENT Bulk Data Entries and is printed by default in Fixed format.
$ TRIM CASE: 1
$ ELASTIC (AERODYNAMIC + APPLIED - INERTIAL) LOADS
FORCE 110000001 0 1.0 0.0E+00 0.0E+00-8.9E-02
FORCE 110000002 0 1.0 0.0E+00 0.0E+00-7.9E-02
FORCE 110000003 0 1.0 0.0E+00 0.0E+00-8.7E-02
FORCE 110000004 0 1.0 0.0E+00 0.0E+00-9.2E-02
FORCE 110000005 0 1.0 0.0E+00 0.0E+00-9.1E-02
FORCE 110000006 0 1.0 0.0E+00 0.0E+00-8.6E-02
FORCE 110000006 0 1.0 0.0E+00 0.0E+00-7.9E-02
FORCE 110000007 0 1.0 0.0E+00 0.0E+00-1.7E-01
FORCE 110000009 0 1.0 0.0E+00 0.0E+00-8.7E-02
FORCE 110000010 0 1.0 0.0E+00 0.0E+00-7.9E-02
FORCE 110000011 0 1.0 0.0E+00 0.0E+00-8.9E-02
