_bdst.mvw file
The _bdst.mvw file is a HyperView session file.
File Creation
This file is only created for Static Subcases. Creation of this file is controlled by the BORE Bulk Data Entry.
File Contents
This file is a HyperView session file and may be opened from the File menu in HyperView or HyperGraph. The file contains HyperGraph plots of Bore Deformation Magnitude versus Bore Depth (Z-depth) and Circularity versus Bore Depth (Z-depth). The plots display the Bore Z-depth on the x-axis and the Bore Deformation Magnitude and Circularity on the y-axis. Different plots are available depending on the ORDER field on the BORE Bulk Data Entry.
- This file is generated for Static Subcases and only if the BORE Bulk Data Entry is defined in the model.
