.force file
The .force file is an OptiStruct ASCII format results file.
Attention: Valid for Implicit and Explicit Analysis
File Creation
Creation of this file is controlled by the FORCE (ELFORCE) I/O Option.
File Contents
Result Description
Force Force results from Linear Static Analysis for ELAS (CELAS1, CELAS2, CELAS3, CELAS4), ROD (CROD), BAR (CBAR, CBEAM), BUSH (CBUSH), PLATE (CQUAD, CTRIA), and GAP (CGAP) elements.
Force results from Normal Modes Analysis for ELAS (CELAS1, CELAS2), ROD (CROD), BAR (CBAR), PLATE (CQUAD4, CQUAD8, CTRIA3, CTRIA6, CSHEAR), SHEAR (CSHEAR), BUSH (CBUSH), GAP (CGAP, CGAPG), CONTACT (CGAPG), WELD (CWELD), and FAST (CFAST) elements.
Force results from Linear Transient Analysis for ELAS (CELAS1, CELAS2), BAR (CBAR), ROD (CROD), BUSH (CBUSH), WELD (CWELD), PLATE (CQUAD4, CQUAD8, CTRIA3, CTRIA6, CSHEAR) elements.
File Format
The file is divided up by iteration. Output from each iteration starts with a line in the following format:
ITER Iteration_number Number_of_subcases/Number_of_Modes
Where,
Data
ITER
Keyword denoting the beginning of a new iteration.
Iteration_number
Iteration number.
Number_of_subcases
Number of subcases for which this output is created.
Number_of_Modes
Total number of modes of all subcases for which this output is created.
Static Analysis
Each iteration section is divided up by subcase. Output for each subcase starts with a line in the following format:
Id Number_of_elements Frequency LOAD:Spc_id(Datatype) subcase_label
Where,
Data
ID
Output identification number for the subcase. This is not the same as the subcase ID used in the input data.
Number_of_elements
Number of elements for which this output is requested.
Frequency
1.0
Static analysis.
LOAD
Keyword declaring applied load information.
Spc_id
The SID for SPC's referenced by this subcase.
(Datatype)
Keyword indicating the type of subcase involved.
(LOAD) declares data is for a linear static subcase.
Each section under iteration is divided up by subcase. Output for each subcase starts with a line in the following format:
Id Number_of_elements FREQ: FRID freq Subcase_label
Where,
Data
ID
Number_of_elements
FREQ
Keyword identifying the modal frequency.
FRID
ID of the modal frequency for which output is printed.
Freq
Value of the modal frequency for which the output is printed.
(Datatype)
Linear Static Analysis .force File Example
Each subcase section is divided up by element type. Output for each element type section starts with one of the following formats (depending on the elements present in the model):
ELAS #	FORCE
ROD#	FORCE-A	FORCE-B
BUSH#	F-X	F-Y	F-Z	M-X	M-Y	M-Z
BAR#	END	AXIAL	SHEAR-1	SHEAR-2	TORQUE	BENDING-1	BENDING-2
PLATE#	MEMB-X	MEMB-Y	MEMB-XY	BEND-X	BEND-Y	TWIST-XY	SHEAR-XZ	SHEAR-YZ
GAP#	COMP-X	SHEAR-Y	SHEAR-Z
Element force output is then listed under these headings, depending on the type of elements for which this output was selected. The format of the element output matches the corresponding header, that is for ROD elements you would get FORCE-A and FORCE-B; whereas, for PLATE elements you would get MEMB-X, MEMB-Y, MEMB-XY, BEND-X, BEND-Y, TWIST-XY, SHEAR-XZ, SHEAR-YZ.
The format is:
Eid value1 value2 value3 etc.
Where,
Data
Eid
Element identification number.
value#
Force result corresponding to the column header.
Subcase Id Label
Time Time
Result Type (Entity Type) [Format]
Where,
Data
Id
Label
Subcase level.
Time
Time increment information.
Entity Type
Beam, Rod, Plate, and so on.
Complex, Real, Imaginary, Phase, and so on.
Where,
Data
EID
Value#
Force information for each element is then provided in the following format:
Within the subcase section, the following information is provided for each grid:
EID value1 value2 value3 value4 value5 value6 value7
Average Force Results
Average force results are available for CBAR and CBEAM elements only when the AVG option is used in the FORCE (ELFORCE) output request.
The output is printed after the end forces for each element.
<end forces>
BAR #      AXIAL      SHEAR-1     SHEAR-2     TORQUE     BENDING-1   BENDING-2
  1. The I/O Option Previously Supported Results controls the frequency of output for analytical results during an optimization.
