Results Output by OptiStruct
The tables in this section summarize the results output for different analysis types. They show the formats available for each result and the I/O Option Entry that controls the output of the result.
The columns represent the major output streams:
H3D
Hyper3D format (.h3d file
HM
HyperMesh format (.res file)
OP2
Nastran Output2 format (.op2 file)
PCH
Nastran Punch format (.pch file)
OPT
OptiStruct ASCII format (multiple files)
PAT
Patran and Alternative-Patran formats (multiple files)
H3D (MBD)
Hyper3D format for body results (_mbd.h3d file)
MRF
Multibody results file (_mbd.mrf file)
HDF5
Hierarchical data format (.h5 file)
Linear Static Analysis and Nonlinear Static Analysis Results
H3D HM OP2 PCH OPTI PAT HDF5 Controlling I/O Option
Nodal Displacements DISPLACEMENT
Element Strain Energy ESE
Element Stresses4 STRESS / ELSTRESS
Element Strains 4 STRAIN
Ply Stresses CSTRESS
Composite Failure Indices CFAILURE
Ply Strains CSTRAIN
Element Forces # FORCE / ELFORCE
Failure output for elements FAILURE
Grid Point Stresses GPSTRESS / GSTRESS
SPC Forces # SPCFORCE
MPC Forces # MPCFORCE
Grid Point Forces ✓* ✓* # GPFORCE
Applied Loads # OLOAD
Contact Force and Pressure CONTF
Total Force TOTALFORCE
Section Resultant Forces RESULTANT
Section Moments RESULTANT
# Available only for Linear Static Analysis
* Also available for linear static analysis preloaded with large displacement analysis
Linear Steady-state Heat Transfer Analysis Results
H3D OP2 PCH Controlling I/O Option
Nodal Temperatures THERMAL
Element Fluxes and Gradients FLUX
SPC Flux SPCFORCE
Linear Transient Heat Transfer Analysis Results
Normal Modes Analysis Results
Eigenvectors DISPLACEMENT
Element Kinetic Energy EKE
Grid Point Energy GPKE
Grid Point Stress GPSTRESS / GSTRESS
Element Stresses 4 STRESS / ELSTRESS
Element Forces FORCE / ELFORCE
SPC Forces SPCFORCE
MPC Forces MPCFORCE
Grid Point Forces GPFORCE
Nodal Pressures (Fluid) PRESSURE
Ply Strains CSTRAIN
Complex Eigenvalue Analysis Results
H3D OP2 PCH HDF5 Controlling I/O Option
Element Energy Loss Per Cycle EDE
Equivalent Radiated Power ERP
Linear Buckling Analysis Results
H3D HM OP2 PCH OPTI HDF5 Controlling I/O Option
Shell Element Forces FORCE
Aeroelastic Divergence Analysis Results
Result H3D OP2 PCH Controlling I/O Option
Eigenvectors # # DISPLACEMENT
Element Energy Loss Per Cycle # EDE
Element Kinetic Energy # EKE
Element Strain Energy # ESE
# In aeroelastic divergence analysis with multiple Mach numbers, only H3D output is available.
Aeroelastic Flutter Analysis
Modal Participation Displacements* # SDISPLACEMENT
* SDISPLACEMENT output is available only for K, PK and PKNL methods of aeroelastic flutter analysis.
# PCH output for SDISPLACEMENT is available only in sorting = SORT1.
Frequency Response Analysis Results
H3D HM OP2 PCH OPTI HDF5 XYPUNCH Controlling I/O Option
Modal Participation Displacements SDISPLACEMENT
Nodal Velocities VELOCITY
Modal Participation Velocities SVELOCITY
Nodal Accelerations ACCELERATION
Modal Participation Accelerations SACCELERATION
Element Stresses 4, 2 STRESS / ELSTRESS
Element Strains 4, 2 STRAIN
Modal Stresses 3 STRESS / ELSTRESS
Modal Strains 3 STRAIN
Element Forces 1 FORCE / ELFORCE
SPC Forces SPCFORCE
MPC Forces MPCFORCE
Power Flow Field POWERFLOW
Ply Strains CSTRAIN
Sound Power
Sound Intensity SINTENS
Sound Pressure Level SPL
Applied Load Vectors OLOAD
  1. Element Forces include CELAS2, CBUSH, CBAR/CBEAM, CROD/CONROD, Plate elements, Solid elements.
  2. Element Stress/Stress include CBEAM/CBAR, Plate elements, Solid elements.
Coupled Frequency Response Analysis of Fluid-structural Models (Acoustic Analysis) Results
SPC Forces SPCFORCE
MPC Forces MPCFORCE
Ply Stress CSTRESS
Ply Strain CSTRAIN
Applied Forces via ACSRCE OLOAD
Transient Analysis Results
SPC forces SPCFORCE
Grid point forces GPFORCE
MPC Forces MPCFORCE
Ply Strains CSTRAIN
Transient Analysis via Fourier Transformation Results
H3D HM OP2 PCH OPTI Controlling I/O Option
Pressure (for Infinite Element Analysis) DISPLACEMENT
Steady State Analysis
Steady State analysis refers to subcases with ANALYSIS=STEADY where a combination of Frequency Response and Linear static subases are converted into and results are output in the Transient domain.
H3D HM OP2 PCH Controlling I/O Option
Stresses STRESS
Equivalent Radiated Power (ERP) ERP
Random Response Analysis Results
OP2 PCH H3D HDF5 Controlling I/O Option
Displacement
(PSD, RMS and RMS (Cumulative))
# DISPLACEMENT, XYPEAK / XYPLOT / XYPUNCH
Velocity
# VELOCITY, XYPEAK / XYPLOT / XYPUNCH
Acceleration
# ACCELERATION, XYPEAK / XYPLOT / XYPUNCH
Element Force
(PSD and RMS)
1 FORCE / ELFORCE, XYPEAK / XYPLOT / XYPUNCH
Element Stress
(PSD)
2 STRESS / ELSTRESS, XYPEAK / XYPLOT / XYPUNCH
Element Stress
(RMS)
1 2 STRESS / ELSTRESS
Element Strain
(PSD)
2 STRAIN, XYPEAK / XYPLOT / XYPUNCH2
Element Strain
(RMS)
2 STRAIN
SPC Force
(PSD, RMS and RMS)
# SPCFORCE
Composite Stress
(PSD and RMS)
3 CSTRESS
Composite Strain
(PSD and RMS)
3 CSTRAIN
Acoustic panel participation factors PFPANEL
Cross-power spectral density function RCROSS
  1. Supported elements for ELEMENT FORCE(HDF5,H3D): CBAR, CBEAM, CBUSH
  2. Supported elements for ELEMENT STRESS/STRAIN( (HDF5): CBAR, CBEAM, CQUAD4, CTRIA3, CQUAD8, CTRIA6, CHEXA, CPENTA, CTETRA, CSHEAR
  3. Supported elements for CSTRAIN(HDF5): CQUAD4, CTRIA3, CQUAD8, CTRIA6
  4. Supported elements for ELEMENT FORCE(H3D): CQUAD4, CTRIA3, CTRIA6, CQUAD8
# In case of .pch format, only PSD and RMS results are available
Response Spectrum Analysis Results
Element Stresses STRESS / ELSTRESS
Element Strains STRAIN
MPC Forces MPCFORCE
Multibody Dynamics Analysis Results
H3D HM OP2 H3D (MBD) MRF Controlling I/O Option
Body time history
System time history
Marker time history REQUEST
Element and Joint Forces MBFORCE
Fatigue Analysis Results
H3D Controlling I/O Option
Element Life LIFE
Element Damage DAMAGE
CMS Generation (Flex-Body Generation) Results
H3D OP2 MNF Controlling I/O Option
Element Forces
(CBEAM/CBAR/CROD)
FORCE / ELFORCE
Grid Point Stress (Solid elements) ✓* ✓* ✓** GPSTRESS / GSTRESS
Grid Point Strain ✓** GPSTRAIN
Multi Point Constraint Force MPCFORCE
* Only output for Solid elements.
** Output for Solid and Shell elements.
CMS DMIG Residual Run (FE DMIG) Results
The following results can be recovered within the superelements in the DMIG residual run (for instance, using CBN DMIG). They should also be specified in the initial DMIG generation run and then in the subsequent residual run for them to be recovered within the superelement in the residual run. For ERP and EKE results, even if only STRESS and STRAIN are specified in the generation run, they can still be recovered in the residual run, as the ERP and ESE output are derived from STRESS and STRAIN results.
Element Strain STRAIN
Element Forces (CBEAM/CBAR/CROD) FORCE / ELFORCE
Grid Point Stress (Solid elements) ✓* GPSTRESS / GSTRESS
* Only output for solid elements.
Explicit Dynamic Analysis Results (ANALYSIS=NLEXPL)
H3D5 HM OP2 PCH OPTI Controlling I/O Option
Nodal Displacements and Rotations DISPLACEMENT
Element Strains (including Plastic strain)
For rate dependent plasticity problems, Equivalent Strain rate and Plastic Strain rate results are output. If the problem is elastic, these values are zero.
STRAIN
CBUSH Element Forces FORCE / ELFORCE
Element Strain energy and Strain energy density ESE
Grid Point Stress ✓* GPSTRESS / GSTRESS
Grid Point Strain ✓* GPSTRAIN
* Only available for solid elements.
Optimization Results
H3D HM OP2 PCH OPT PAT Controlling I/O Option
Element Density DENSITY
Element Thickness THICKNESS
Ply Thickness THICKNESS
% Thickness THICKNESS
Shape SHAPE
Electrostatic Analysis Results
Voltage VOLTAGE
Electric Displacement ELECFLUX
Electric Field ELECFIELD
Grid Point Charge GPCHARGE
Applied Nodal Charge OLOAD
Reaction Charge SPCCHARGE
MPC Charge* MPCFORCE
Electrostatic Force ESTATFORCE
* MPC Charge = Free Charge inducted on outer surface of a conductor
Currently, results are available in .h3d format in a separate *_estat.h3d file. Electrostatic force can be output in ASCII format.
References
1 Only RMS Stress (total over all frequencies) are output to the PCH file. RMS Stress (cumulative up to a particular frequency) are not output to PCH file.
2 XYPLOT output request is not supported for Shell Strains.
3 The Structural Modal Stresses and Strains and Residual Vectors are output in Modal Frequency Response Analysis via the STRESS (MODAL) and STRAIN (MODAL) options. A possible use-case for Modal Strains is to setup Modal FRF/Modal Transient Analysis and use the Modal Participation Factors and Modal Strains as input for Fatigue Analysis.
4 The element stress and strain results written to the various output streams are not always the same. Refer to the following pages for more details on the stress results available in the different output streams.
5 For Explicit Dynamic Analysis H3D results are output in *_expl.h3d file.
