Stress Results Written in Nastran .op2 and .pch Formats
Static, Transient and Multibody Loadcases
1D Elements
CROD Axial Stress
CELAS Stress
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
Note: SA1-SA4 and SB1-SB4 are bending stress.
CBEAM Long Stress at Point C1
CBEAM Long Stress at Point D1
CBEAM Long Stress at Point E1
CBEAM Long Stress at Point F1
CBEAM Maximum Stress1
CBEAM Minimum Stress1
CBEAM Long Stress at Point C2
CBEAM Long Stress at Point D2
CBEAM Long Stress at Point E2
CBEAM Long Stress at Point F2
CBEAM Maximum Stress2
Note: Long Stress means axial stress + bending stress.
CBEAM Minimum Stress2
CWELD Axial Stress
CWELD Maximum Stress A
CWELD Minimum Stress A
CWELD Maximum Stress B
CWELD Minimum Stress B
CWELD Maximum Shear Stress
CWELD Bearing Stress
2D Elements
Fibre Distance (Z1)
Normal XX Stress (Z1)
Normal YY Stress (Z1)
Shear XY Stress (Z1)
Principal Stress Angle (Z1)
Major Principal Stress (Z1)
Minor Principal Stress (Z1)
von Mises Stress (Z1)
Fibre Distance (Z2)
Normal XX Stress (Z2)
Normal YY Stress (Z2)
Shear XY Stress (Z2)
Principal Stress Angle (Z2)
Major Principal Stress (Z2)
Minor Principal Stress (Z2)
von Mises Stress (Z2)
3D Elements
Normal XX Stress
Shear XY Stress
Major Principal X Cosine
Mid Principal X Cosine
Minor Principal X Cosine
Mean Stress
von Mises Stress
Normal YY Stress
Shear YZ Stress
Mid Principal Stress
Major Principal Y Cosine
Mid Principal Y Cosine
Minor Principal Y Cosine
Normal ZZ Stress
Shear XZ Stress
Minor principal Stress
Major Principal Z Cosine
Mid Principal Z Cosine
Minor Principal Z Cosine
1D Elements
CROD Axial Stress
CELAS Stress
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
2D Elements
Fibre Distance (Z1)
Fibre Distance (Z2)
3D Elements
Normal XX Stress
Shear XY Stress
Mean Stress
von Mises Stress
Normal YY Stress
Shear YZ Stress
Normal ZZ Stress
Shear XZ Stress
Eigenvalue Loadcases
1D Elements
None
2D Elements
Fibre Distance (Z1)
Fibre Distance (Z2)
3D Elements
Normal XX Stress
Shear XY Stress
Mean Stress
von Mises Stress
Normal YY Stress
Shear YZ Stress
Normal ZZ Stress
Shear XZ Stress
Frequency Response Loadcases
1D Elements
CROD Axial Stress
CELAS Stress
CBAR SA1
CBAR SA2
CBAR SA3
CBAR SA4
CBAR Axial
CBAR SA-maximum
CBAR SA-minimum
CBAR SB1
CBAR SB2
CBAR SB3
CBAR SB4
CBAR SB-maximum
CBAR SB-minimum
2D Elements
Fibre Distance (Z1)
Normal XX Stress (real) (Z1)
Normal XX Stress (imag) (Z1)
Normal YY Stress (real) (Z1)
Normal YY Stress (imag) (Z1)
Shear XY Stress (real) (Z1)
Shear XY Stress (imag) (Z1)
Fibre Distance (Z2)
Normal XX Stress (real) (Z2)
Normal XX Stress (imag) (Z2)
Normal YY Stress (real) (Z2)
Normal YY Stress (imag) (Z2)
Shear XY Stress (real) (Z2)
Shear XY Stress (imag) (Z2)
3D Elements
Normal ZZ Stress (real)
Shear YZ Stress (real)
Shear XZ Stress (real)
Normal ZZ Stress (imag)
Shear YZ Stress (imag)
Shear XZ Stress (imag)
  1. The order above reflects the contents of the OP2 file, but post-processors such as HyperView may display results in a different manner.
  2. For 2D elements, results are printed at the center of the element, followed by results at each grid when corner stresses are requested.
  3. For 3D elements, results are printed at the center of the element, followed by results at each grid when corner stresses are requested. In the OP2 format, regardless of the corner stress request, results are printed at each grid by duplicating results at the center.
