- .#.#.#.dis file
The .#.#.#.dis file is a Patran 2.5 ASCII format results file.
- .#.#.dis file
The .#.#.dis file is a Patran 2.5 ASCII format results file.
- .#.#.dis.# file
The .#.#.dis.# file is a Patran 2.5 ASCII format results file
- .#.#.els file
The .#.#.els file is a Patran 2.5 ASCII format results file.
- .#.#.fat file
The .#.#.fat file is an ASCII format result file.
- .#.dis file
The .#.dis file is a Patran 2.5 ASCII format results file.
- .#.dis.# file
The .#.dis.# file is a Patran 2.5 ASCII format results file.
- .#.eigv file
The .#.eigv file is an OptiStruct binary data file.
- .#.els file
The .#.els file is a Patran 2.5 ASCII format results file.
- .#.els.# file
The .#.els.# file is a Patran 2.5 ASCII format results file.
- .#.grid file
The .#.grid file is an OptiStruct ASCII format results file.
- .#.h3d file
The .#.h3d files are compressed binary files, containing model, analysis, and optimization result data. They can be used to post-process results in HyperView or when using the HyperView Player.
- .#.mass file
The .#.mass file is an ASCII format results file.
- .#.rnf file
The .#.rnf is an OptiStruct ASCII format results file.
- .#.sens file
The .#.sens file is an OptiStruct ASCII format results file.
- .#.sh file
The .#.sh file is an OptiStruct ASCII format results file.
- .#.slk file
The .slk file is a Microsoft Excel SYLK Format results file.
- .acmfrc file
The .acmfrc file is an OptiStruct ASCII format results file.
- .amls_singularity.cmf file
The .amls_singularity.cmf file is a HyperMesh command file.
- .amses_singularity.cmf file
The .amses_singularity.cmf file is a HyperMesh command file.
- .bdst file
The .bdst file is an OptiStruct ASCII format results file.
- .cmode.csv file
This file is an output file generated during an Acoustic Complex Eigenvalue Analysis.
- .cntf file
An OptiStruct ASCII format results file.
- .contgap.fem file
The .contgap.fem file is an ASCII format file. It is used to visualize the internally created contact elements. The contact elements are presented as CGAPG elements.
- .cpr file
The .cpr file is an OptiStruct ASCII format results file.
- .cstr file
The .cstr file is an OptiStruct ASCII format results file.
- .dens file
The .dens file is an OptiStruct ASCII format results file.
- .desvar file
The .desvar file is an ASCII format result file.
- .dis.# file
The .dis.# file is a Patran 2.5 ASCII format results file.
- .disp file
The .disp file is an OptiStruct ASCII format results file.
- .dvgrid file
The .dvgrid file is an OptiStruct ASCII format results file.
- .echo file
The .echo file is an OptiStruct input file.
- .effmass file
The .effmass file is an OptiStruct ASCII format results file.
- .els.# file
The .els.# file is a Patran 2.5 ASCII format results file.
- .flst file
An OptiStruct XML format file.
- .flt file
An OptiStruct ASCII format results file containing the summary of aeroelastic flutter analysis.
- .force file
The .force file is an OptiStruct ASCII format results file.
- .fsthick file
The .fsthick file is an OptiStruct ASCII format file.
- .full.mat file
- .gpf file
The .gpf file is an OptiStruct ASCII format results file.
- .grid file
The .grid file is an OptiStruct ASCII format results file.
- .h3d file
The .h3d file is a compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or when using the HyperView Player.
- .h5 file
A binary file, containing model and result data.
- .hgdata file
The .hgdata file is a HyperGraph ASCII results file.
- .hist file
The .hist file is an OptiStruct ASCII format results file.
- .HM.autospc.cmf file
The .HM.autospc.cmf file is a HyperMesh command file.
- .HM.comp.tcl file
The .HM.comp.tcl file is a HyperMesh command file.
- .HM.conn.tcl file
The .HM.conn.tcl file is a HyperMesh command file.
- .HM.crtelem.cmf file
The .HM.crtelem.cmf file is a HyperMesh command file.
- .HM.elcheck.cmf file
The .HM.elcheck.cmf file is a HyperMesh command file.
- .HM.elcheck.###.cmf file
The .HM.elcheck_###.cmf file is a HyperMesh command file.
- .HM.ent.tcl file
The .HM.ent.tcl file is a HyperMesh command file.
- .HM.gapstat.cmf file
The .HM.gapstat.cmf file is a HyperMesh command file.
- .html file
The .html file is a HyperText Markup Language file.
- .interface file
The .interface file is an ASCII format results file.
- .joint file
The .joint file is an ASCII format results file.
- .k.op2 file
The .k.op2 file is a Nastran output2 format file containing the stiffness matrix.
- .kpi file
- .load file
The .load file is an OptiStruct ASCII format results file.
- .m.op2 file
The .m.op2 file is a Nastran output2 format file containing the mass matrix.
- .mapdsp file
The .mapdsp file is an OptiStruct ASCII format results file.
- .mass file
The .mass file is an OptiStruct ASCII format results file.
- .mgg file
The .mgg file is an ASCII format results file.
- .mnf file
The .mnf file is an ADAMS modal neutral file.
- .monitor file
- .monpnt file
The .monpnt file is an OptiStruct ASCII format results file.
- .mpcf file
The .mpcf file is an OptiStruct ASCII format results file.
- .op2 file
The .op2 file is a Nastran output2 format for model and results data.
- .oss file
The .oss file is an OSSmooth parameter file.
- .out file
An ASCII format results file.
- .pch file
The .pch file is a Nastran punch format results file.
- .pcomp file
The .pcomp file is an ASCII format result file.
- .peak file
The .peak file is an ASCII format results file.
- .pret file
The .pret file is an OptiStruct ASCII format results file.
- .prop file
The .prop file is an OptiStruct ASCII format result file.
- .rand file
The .rand file is an OptiStruct ASCII format results file.
- .reduced.mat file
- .rengy file
The .rengy file is an ASCII results file.
- .res file
The .res file is a HyperMesh binary results file.
- .secres file
The .secres file is an OptiStruct ASCII format results file.
- .seplot file
The .seplot file is an ASCII format output file.
- .sh file
The .sh file is an OptiStruct ASCII format results file.
- .spcd file
The .spcd file is an OptiStruct ASCII format results file.
- .spcf file
The .spcf file is an OptiStruct ASCII format results file.
- .stat file
The .stat file is an ASCII format results file.
- .strn file
The .strn file is an ASCII format results file.
- .strs file
The .strs file is an OptiStruct ASCII format results file.
- .trf file
An ASCII format results file which contains Bulk Data of loads from Aeroelastic Analysis results.
- .trim file
An ASCII format results file which contains Aeroelastic Analysis results.
- _bdst.mvw file
The _bdst.mvw file is a HyperView session file.
- _des.h3d file
A compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or when using the HyperView Player.
- _e.nlm file
The _e.nlm file is an OptiStruct ASCII format results file.
- _e.out file
An ASCII format results file which can be used for monitoring energy output from nonlinear analysis.
- _energy.mvw file
The _energy.mvw file is a HyperGraph session file.
- _err.grid file
The _err.grid file is an OptiStruct ASCII format results file.
- _expl.cntf file
- _fat.#.eqsts file
- _frames.html file
The _frames.html file is a HyperText Markup Language file.
- _freq.#.mvw file
The _freq.#.mvw file is a HyperView session file.
- _freq.mvw file
The _freq.mvw file is a HyperView session file.
- _gauge.h3d file
A compressed binary file containing both model and result data. It can be used to post-process shell thickness (gauge) sensitivity in HyperView.
- _gso.slk file
The _gso.slk file is a Microsoft SLK Data Import format results file.
- _hist.mvw file
The _hist.mvw file is a HyperView session file.
- _impl.h3d file
- _ld.monitor file
The _ld.monitor file is an OptiStruct ASCII format results file.
- _mass.#.mvw file
The _mass.#.mvw file is a HyperView session file.
- _mass.mvw file
The _mass.mvw file is a HyperView session file.
- _mbd.h3d file
A compressed binary file containing both model and result data from a multibody dynamics analysis. It can be used to post-process results in HyperView.
- _mbd.log file
The _mbd.log file is an ASCII format .log file from a multibody dynamics analysis.
- _mbd.mrf file
The _mbd.mrf file is a Multibody Results File.
- _mbd.mvw file
The _mbd.mvw file is a HyperView session file.
- _mbd.xml file
The _mbd.xml file is a MotionSolve .xml file from a multibody dynamics analysis.
- _menu.html file
The _menu.html file is a HyperText Markup Language file.
- _modal.#.mvw file
The _modal.#.mvw file is a HyperView session file.
- _modal.mvw file
The _modal.mvw file is a HyperView session file.
- _nl.h3d file
A compressed binary file, containing both model and result data. It is output when either NLMON Subcase/Bulk Entry pair or PARAM,NLMON is specified in the input file.
- _nl.out file
An ASCII format results file which can be used for monitoring and debugging of nonlinear analysis.
- _rand.mvw file
The _rand.mvw file is a HyperView session file.
- _s#.h3d file
The _s#.h3d file is a compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or using the HyperView Player.
- _s#_a.#.frf file
The _s#_a.#.frf file is an OptiStruct ASCII format results file.
- _s#_a.frf file
The _s#_a.frf file is an OptiStruct ASCII format results file.
- _s#_a.mbd file
The _s#_a.mbd file is an OptiStruct ASCII format results file.
- _s#_a.trn file
The _s#_a.trn file is an OptiStruct ASCII format results file.
- _s#_d.#.frf file
The _s#_d.#.frf file is an OptiStruct ASCII format results file.
- _s#_d.frf file
The _s#_d.frf file is an OptiStruct ASCII format results file.
- _s#_d.mbd file
The _s#_d.mbd file is an OptiStruct ASCII format results file.
- _s#_d.trn file
The _s#_d.trn file is an OptiStruct ASCII format results file.
- _s#_s.trn file
- _s#_v.#.frf file
The _s#_v.#.frf file is an OptiStruct ASCII format results file.
- _s#_v.frf file
The _s#_v.frf file is an OptiStruct ASCII format results file.
- _s#_v.mbd file
The _s#_v.mbd file is an OptiStruct ASCII format results file.
- _s#_v.trn file
The _s#_v.trn file is an OptiStruct ASCII format results file.
- _sens.#.mvw file
The _sens.#.mvw file is a HyperView session file.
- _shuffling.#.fem file
The _shuffling.#.fem file is an ASCII format file.
- _sizing.#.fem file
The _sizing.#.fem file is an ASCII format file.
- _sizing.#.inc file
The _sizing.#.inc file is an ASCII format file.
- _TH.h5 file
This is a binary file that contains time history output from Explicit Dynamic Analysis in Hierarchical Data Format, Version 5.
- _topol.h3d file
The _topol.h3d file is a compressed binary file containing both model and result data. It can be used to post-process topology (density) sensitivity in HyperView.
- _tran.mvw file
The _tran.mvw file is a HyperView session file.
- <BODY_NAME>.h3d file
The <BODY_NAME>.h3d file is a compressed binary file from a multibody dynamics analysis that uses flexible bodies defined through a PFBODY Bulk Data Entry.
