_e.nlm file
The _e.nlm file is an OptiStruct ASCII format results file.
File Creation
This file is output by default for any Implicit Nonlinear Analysis run. For entity-specific energy output, the NLENRG Bulk/Subcase Entry pair can be used. Such available entities are Element SETs, Contact Interfaces, Property Groups of CGAP/CGAPG elements.
  • Default output is printed in filename_s<n>_e.nlm files for each nonlinear subcase, where <n> denotes the subcase ID.
  • Entity-specific energy output if activated, is named as:
    • filename_eset<ID>_s<n>_e.nlm
    • filename_cont<ID>_s<n>_e.nlm
    • filename_pgap<ID>_s<n>_e.nlm
      for each entity in each nonlinear subcase, where <ID> denotes the entity ID and <n> the subcase ID.
File Contents
Result
Time
Timesteps
Strain Energy
Strain Energy
Contact Stabilization Energy
Energy dissipated by artificial static contact stabilization
Plastic Dissipation Energy
Energy dissipated by plastic deformation
Static Stabilization Energy
Energy dissipated by artificial static stabilization
Sum of Contact Stabilization Energy and Static Stabilization Energy for the entire model (all contact pairs) or for the contact IDs defined through NLENRG
File Format
The file is a simple table with time steps and results in multiple columns.
