_topol.h3d file
The _topol.h3d file is a compressed binary file containing both model and result data. It can be used to post-process topology (density) sensitivity in HyperView.
File Creation
This file is created when an optimization is performed. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
The _topol.h3d file contains node and element definitions in addition to the
following results:
Result | Description |
Sensitivity | Sensitivity of
response versus element density from topology
optimization. Output is controlled by the I/O Option OUTPUT. |
- A single _topol.h3d file is created for all iterations.
