.monpnt file
The .monpnt file is an OptiStruct ASCII format results file.
File Creation
This file is created when the model has at least one load monitor point
(MONPNT1/ MONPNT2/
MONPNT3) defined and:
- For linear static analysis, the .monpnt file will be generated only in the presence of the MONITOR I/O Options Entry.
- For static aeroelastic analysis, the .monpnt file will be generated automatically.
File Content
This file contains integrated load monitor point results from linear static analysis and static aeroelastic analysis. Each monitor point section is divided up by subcase. Output for each subcase starts with a line in the following format.
File Format
The .monpnt file has the following format for each monitor point.
MONTPNT1 Output Format
Header
The following header is used:
<DOMAIN> M O N I T O R P O I N T I N T E G R A T E D L O A D
S
| MONITOR POINT NAME | COMPONENT | SUBCASE NO. | ||||
| LABEL | ||||||
| CP | X | Y | Z | CD | ||
Loads information then is provided for each monitor point in the following
format:
| AXIS | RIGID AIR | ELASTIC REST. | INERTIAL | RIGID APPLIED | REST APPLIED |
| Field | Contents |
| DOMAIN | Denotes the output domain for the monitor point integrated
loads.
| MONITOR POINT NAME | Name of the MONTPNT1 Bulk Data Entry. |
| COMPONENT | Output domain. |
| SUBCASE NO. | Subcase ID referenced by this monitor point. |
| LABEL | Label of the MONTPNT1 Bulk Data Entry. |
| CP | Input coordinate system. |
| X | X coordinate of the monitor point. |
| Y | Y coordinate of the monitor point. |
| Z | Z coordinate of the monitor point. |
| CD | Output coordinate system. |
| AXIS | Axis in the CD coordinate system. |
| CX,CY,CZ,CMX,CMY,CMZ | Force and moment coefficients in the CD coordinate system. |
| RIGID AIR | Aerodynamic load coefficients assuming that the structure is rigid. |
| ELASTIC REST. | Aerodynamic load coefficients assuming that the structure is deformable. |
| INERTIAL | Inertial load coefficients at the
location of the monitor point. Note: It is not applicable for the
aeroelastic domain, as you do not consider
mass. |
| RIGID APPLIED | Resultant applied load at the location of the monitor point
assuming that the structure is rigid. Note: It is not applicable
for the aeroelastic domain, as you do not apply the
loads. |
| REST APPLIED | Resultant applied load on at the location of the monitor point. |
MONTPNT2 Output Format
Header
S| MONITOR POINT NAME | SUBCASE NO. |
Loads, Stress or Strain information is then provided for each element in the
following format:
| VALUE EID |
ETYPE | CLASS | RESPONSE | LABEL |
| Field | Contents |
loads.
| MONITOR POINT NAME | Name of the MONTPNT2 Bulk Data Entry. |
| VALUE | Magnitude of the result type. |
| EID | Element ID. |
| ETYPE | Element type. |
| CLASS | Result type. |
| RESPONSE | Item code for the corresponding result. Note: Refer to MONPNT2 - NDDL Item Codes for more
details. |
| LABEL | Results are labeled as combination of Name and label of the MONPNT2 card |
MONTPNT3 Output Format
Header
S| MONITOR POINT NAME | SUBCASE NO. | ||||
| LABEL | |||||
Loads information is then provided in the following format:
| AXIS | ELASTIC REST. | REST APPLIED |
| Field | Contents |
loads.
| MONITOR POINT NAME | Name of the MONTPNT3 Bulk Data Entry. |
| LABEL | Label of the MONTPNT3 Bulk Data Entry. |
