.full.mat file
An OptiStruct ASCII format results file.
File Creation
This file is created when the OUTPUT,MATRIX,FULL,DENSE/SPARSE I/O Options Entry is used.
File Contents
- Output
- Description
- Full Stiffness Matrix
- Is output by default or if the DENSE option is selected. If SPARSE is selected, then the sparse matrix with all the zeros excluded, is printed in the <filename>.full.mat file.
- Full Mass Matrix
- Is output by default or if the DENSE option is selected, for dynamic analysis. If SPARSE is selected, then the sparse matrix with all the zeros excluded, is printed in the <filename>.full.mat file.
- Full Heat Capacity Matrix
- This matrix is output for Linear Transient Heat Transfer. It is output by default or if the DENSE option is selected. If SPARSE is selected, the sparse matrix with all the zeros excluded is printed in the <filename>.full.mat file.
- Full Conductivity Matrix
- Full Convection Matrix
- Grid-to-DOF Mapping Matrix
- The full Grid-to-DOF mapping matrices are printed in the <filename>.full.mat file. For Linear Transient Heat Transfer analysis, the full Grid-to-Heat DOF mapping matrix is also printed.
File Format
- Name
- Content
- Matrix Name
- Identifies the matrix name (STIFFNESS, MASS, DOFS, CONDUCTIVITY, CONVECTION, CAPACITY, or DOFSHT)
- ID
- Is always 0 for full matrix output (for the <filename>.full.mat file)
- Number Type
- Identifies whether the matrix elements are Integers (1), Real (2), or Complex (3) numbers
- Matrix Type
- Identifies the matrix type of Dense (1) or Sparse (3) matrix
- Matrix Size (mxn)
- Indicates the size of the matrix (m columns and n rows)
- Precision Information
- Fortran precision information
- Matrix Data
- Matrices are presented as a list of Columns with a range of row elements for each column ID.
