.peak file
The .peak file is an ASCII format results file.
File Creation
This file is created when XYPLOT, XYPEAK, or XYPUNCH is requested in random response analysis.
File Contents
This file contains the root mean square value, the number of positive crossings, and the peak power spectral density and responses.
