_hist.mvw file
The _hist.mvw file is a HyperView session file.
File Creation
This file is created when an optimization is performed. Creation of this file is controlled by the I/O Option DESHIS.
File Contents
This _hist.mvw file additionally contains the following information based on
the OUTPUT,HGHIST options:
- The file automatically creates individual plots for each of the results contained in the .hist file.
- Normalized constraint violation plots. Value 32 outputs the plot for responses divided by their corresponding constraint bounds to the *_hist.mvw file. The response over constraint bound (Y-Axis) versus Response ID (X-Axis) plots are only output for the final optimization iteration. The responses ID’s are not equivalent to the user-defined Response ID’s in the model. To identify any response, hover the mouse pointer over red vertical curve in HyperGraph, this will display the user-defined Response Label. The Y-Axis value of 1.0 is displayed as a red horizontal line.
Each plot occupies its own page within HyperView (HyperGraph).
