DRESP1 – Geometric Response Item Codes
- Item Code
- Geometric Response Item
- ANGLE
- Angle between the location of 3 grids
- LENGTH
- Distance between the location of 2 grids
- AREA3
- Area or deform area of triangle
- AREA4
- Area or deform area of quadrilateral
- VOL4
- Volume or deform volume of a solid tetrahedral
- VOL5
- Volume or deform volume of a solid pyramid
- VOL6
- Volume or deform volume of a solid pentahedral
- VOL8
- Volume or deform volume of a solid hexahedral
- DGLINE
- Distance or deform distance from point to line
- DGPLANE
- Distance or deform distance from point to plane
- DIFFX
- Difference between the locations x of grid 2 and grid 1
- DIFFY
- Difference between the locations y of grid 2 and grid 1
- DIFFZ
- Difference between the locations z of grid 2 and grid 1
- DISTX
- Absolute value of the difference between the locations x of grid 2 and grid 1
- DISTY
- Absolute value of the difference between the locations y of grid 2 and grid 1
- DISTZ
- Absolute value of the difference between the locations z of grid 2 and grid 1
- LOCX
- Location x of grid
- LOCY
- Location y of grid
- LOCZ
- Location z of grid
- PXAREA3
- Projected area or deformed area of triangles defined by sets of 3 grids and the x-axis of a user-supplied coordinate system
- PYAREA3
- Projected area or deformed area of triangles defined by sets of 3 grids and the y-axis of a user-supplied coordinate system
- PZAREA3
- Projected area or deformed area of triangles defined by sets of 3 grids and the z-axis of a user-supplied coordinate system
- PXAREA4
- Projected area or deformed area of quadrilaterals defined by sets of 4 grids and the x-axis of a user-supplied coordinate system
- PYAREA4
- Projected area or deformed area of quadrilaterals defined by sets of 4 grids and the y-axis of a user-supplied coordinate system
- PZAREA4
- Projected area or deformed area of quadrilaterals defined by sets of 4 grids and the z-axis of a user-supplied coordinate system
- PXAREA
- Projected area or deformed area of shell elements defined by element IDs and the x-axis of a user-supplied coordinate system
- PYAREA
- Projected area or deformed area of shell elements defined by element IDs and the y-axis of a user-supplied coordinate system
- PZAREA
- Projected area or deformed area of shell elements defined by element IDs and the z-axis of a user-supplied coordinate system
- AREA
- Area or deformed area of shell elements defined by element IDs
Note: If RTYPE = GEORESP (Geometric Response):
- Location x = coordinate x
- Location y = coordinate y
- Location z = coordinate z
If RTYPE = GEODEFR (Geometric
Deformation Response):
- Location x = coordinate x + displacement x
- Location y = coordinate y + displacement y
- Location z = coordinate z + displacement z
The LOCi, DIFFi and DISTi (i = X, Y, Z) geometric responses are calculated in the basic coordinate system.
