DRESP1 - Frequency Response Pressure Item Codes
| Response | Component | ASCII code | Number Code1 |
| Pressure | Real | R-PRES | 1 |
| Imaginary | I-PRES | 7 | |
| Magnitude | M-PRES | 1 | |
| Phase | P-PRES | 7 |
1 OptiStruct provides partial support for Nastran item codes. Since Nastran
response items are not fully compatible with those used in OptiStruct, it is recommended that the OptiStruct
ASCII item codes be used.
