SWLDPRM, PATEXT
Bulk Data Entry Extends the search for a patch of shell elements that support auxiliary points for CWELD with PARTPAT and ELPAT options and for CFAST elements (this is not supported for CSEAM elements).
Parameter | Values | Description |
PATEXT | <YES, NO> |
- When activated, may still fail to find projections of auxiliary points. For example, when the weld is close to the edge of the domain. NREDIA and GSMOVE, when specified are then activated to adjust the locations of auxiliary points into a feasible projection range.
