SWLDPRM, CHKRUN
Bulk Data Entry Stop or allow the run after the connectivities of all the connector elements have been generated. This parameter must be global, meaning it should be placed before the presence of the first connector keyword.
Parameter Values Description
CHKRUN <NO, 0, YES, or 1>
Default = NO
NO or 0
The solver will run to completion, unless other errors are present.
YES or 1
The solver will stop after connectivity of all connector elements has been checked.
