Material Compatibility
Block Format Keyword The following tables list the compatibility options for each of the material laws.
Shell Elements
Law Name SHELL Shell Property
Type 1 Type 9 Type 10 Type 11 Type 16 Type 17 Type 19 Type 51 PCOMPP
/MAT/PLAS_PREDEF √ √ √ √
/MAT/LAW0 (VOID) √ √ √ √ √ √ √ √ √
/MAT/LAW1 (ELAST) √ √ √ √
/MAT/LAW2 (PLAS_JOHNS) √ √ √ √
/MAT/PLAS_ZERIL √ √
/MAT/LAW3 (HYDPLA)
/MAT/LAW4 (HYD_JCOOK)
/MAT/LAW5 (JWL)
/MAT/LAW6 (HYDRO or HYD_VISC)
/MAT/K-EPS
/MAT/LAW10 (DPRAG1)
/MAT/LAW11 (BOUND)
/MAT/B-K-EPS
/MAT/LAW12 (3D_COMP)
/MAT/LAW14 (COMPSO)
/MAT/LAW15 (CHANG) √ √ √ √ √ √
/MAT/LAW16 (GRAY)
/MAT/LAW18 (THERM)
/MAT/LAW19 (FABRI) √ √
/MAT/LAW20 (BIMAT)
/MAT/LAW21 (DPRAG)
/MAT/LAW22 (DAMA) √ √ √ √
/MAT/LAW23 (PLAS_DAMA)
/MAT/LAW24 (CONC)
/MAT/LAW25 (COMPSH) √ √ √ √ √ √ √ √
/MAT/LAW25 (COMPSH) (Tsai-Wu) √ √ √ √ √ √ √ √
/MAT/LAW26 (SESAM)
/MAT/LAW27 (PLAS_BRIT) √ √ √ √ √
/MAT/LAW28 (HONEYCOMB)
USER1 √ √ √ √ √ √ √ √
USER2 √ √ √ √ √ √ √ √
USER3 √ √ √ √ √ √ √ √
/MAT/LAW32 (HILL) √ √ √ √ √
/MAT/LAW33 (FOAM_PLAS)
/MAT/LAW34 (BOLTZMAN) √ √ √ √ √ √ √
/MAT/LAW35 (FOAM_VISC) √ √ √ √ √
/MAT/LAW36 (PLAS_TAB) √ √ √ √ √ √ √ √ √
/MAT/LAW37 (BIPHAS)
/MAT/LAW38 (VISC_TAB)
/MAT/LAW40 (KELVINMAX)
/MAT/LAW41 (LEE_TARVER)
/MAT/LAW42 (OGDEN) √ √ √ √ √ √ √
/MAT/LAW43 (HILL_TAB) √ √ √ √ √ √
/MAT/LAW44 (COWPER) √ √ √ √ √
/MAT/LAW46 (LES_FLUID)
/MAT/LAW48 (ZHAO) √ √ √ √ √
/MAT/LAW49 (STEINB)
/MAT/LAW50 (VISC_HONEY)
/MAT/LAW51 (MULTIMAT)
/MAT/LAW52 (GURSON) √ √ √ √ √
/MAT/LAW53 (TSAI_TAB)
/MAT/LAW54 (PREDIT)
/MAT/LAW57 (BARLAT3) √ √ √ √ √ √
/MAT/LAW58 (FABR_A) √ √ √ √ √
/MAT/LAW59 (CONNECT)
/MAT/LAW60 (PLAS_T3) √ √ √ √ √ √ √
/MAT/LAW62 (VISC_HYP) √ √ √ √ √ √ √
/MAT/LAW63 (HANSEL) √ √ √ √ √
/MAT/LAW64 (UGINE_ALZ) √ √ √ √ √
/MAT/LAW65 (ELASTOMER) √ √ √ √ √
/MAT/LAW66 √ √ √ √ √
/MAT/LAW68 (COSSER)
/MAT/LAW69 √ √ √ √ √ √ √
/MAT/LAW70 (FOAM_TAB)
/MAT/LAW71 √ √ √ √ √ √ √
/MAT/LAW72 (HILL_MMC) √ √ √ √ √
/MAT/LAW73 √ √ √ √ √ √
/MAT/LAW74
/MAT/LAW75 (POROUS)
/MAT/LAW76 (SAMP) √ √ √ √ √ √ √
/MAT/LAW77
/MAT/LAW78 √ √ √ √ √ √ √
/MAT/LAW79 (JOHN_HOLM)
/MAT/LAW80 √ √ √ √ √ √ √
/MAT/LAW81 (DPRAG_CAP)
/MAT/LAW82 √ √ √ √ √ √ √
/MAT/LAW83
/MAT/LAW84
/MAT/LAW87 (BARLAT2000) √ √ √ √ √ √
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW93 (ORTH_HILL) or (CONVERSE) √ √ √ √ √ √ √ √
/MAT/LAW94 (YEOH)
/MAT/LAW95 (BERGSTROM_BOYCE)
/MAT/LAW97 (JWLB)
/MAT/LAW100 (MNF)
/MAT/LAW102 (DPRAG2)
/MAT/LAW103 (HENSEL-SPITTEL)
/MAT/LAW104 (JOHNS_VOCE_DRUCKER) √ √
/MAT/LAW106 (JCOOK_ALM)
/MAT/LAW108 (SPR_GENE)
/MAT/LAW109 √ √ √ √ √ √ √ √ √ √
/MAT/LAW110 (VEGTER) √ √ √ √ √ √ √
/MAT/LAW111
/MAT/LAW112 (PAPER or XIA) √ √ √ √ √ √ √
/MAT/LAW113 (SPR_BEAM)
/MAT/LAW114 (SPR_SEATBELT)
/MAT/LAW115 (DESHFLECK)
/MAT/LAW116
/MAT/LAW117
/MAT/LAW119 (SH_SEATBELT) √ √
/MAT/LAW120 (TAPO)
/MAT/LAW121 (PLAS_RATE) √ √ √ √ √
/MAT/LAW122 (MODIFIED_LADEVEZE) √ √ √ √ √ √ √ √
/MAT/LAW124 (CDPM2)
/MAT/LAW126 (JOHNSON_HOLMQUIST_CONCRETE)
/MAT/LAW127 (ENHANCED_COMPOSITE) √ √ √ √ √ √ √ √
/MAT/LAW133 (GRANULAR)
/MAT/LAW134 (VISCOUS_FOAM)
/MAT/LAW151 (MULTIFLUID)
/MAT/LAW163 (CRUSHABLE_FOAM)
/MAT/LAW169 (ARUP_ADHESIVE)
/MAT/LAW200 (MDS) √ √ √ √ √ √ √ √ √
/MAT/USERij √ √ √ √ √ √ √ √
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
Solids
Law Name Elements Properties
Brick Tetra Thick Shell Type 6 Type 14 Type 20 Type 21 Type 22 Type 43
2D TRIA 2D QUAD 8 node 20 node 4 node 10 node 6 & 8 node 16 node
/MAT/PLAS_PREDEF √ √ √ √ √ √ √ √ √ √
/MAT/LAW0 (VOID) √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW1 (ELAST) √ √ √ √ √ √ √ √ √ √
/MAT/LAW2 (PLAS_JOHNS) √ √ √ √ √ √ √ √ √ √
/MAT/PLAS_ZERIL √ √ √ √ √ √ √ √ √ √
/MAT/LAW3 (HYDPLA) √ √ √ √ √ √ √ √ √
/MAT/LAW4 (HYD_JCOOK) √ √ √ √ √ √ √ √
/MAT/LAW5 (JWL) √ √ √
/MAT/LAW6 (HYDRO or HYD_VISC) √ √ √ √ √ √
/MAT/K-EPS
/MAT/LAW10 (DPRAG1) √ √ √ √ √ √ √ √ √ √
/MAT/LAW11 (BOUND) √ √ √
/MAT/B-K-EPS
/MAT/LAW12 (3D_COMP) √ √ √ √ √ √ √
/MAT/LAW14 (COMPSO) √ √ √ √ √ √ √
/MAT/LAW15 (CHANG)
/MAT/LAW16 (GRAY) √ √ √ √ √
/MAT/LAW18 (THERM) √ √ √ √ √
/MAT/LAW19 (FABRI)
/MAT/LAW20 (BIMAT) √ √
/MAT/LAW21 (DPRAG) √ √ √ √ √ √ √ √ √ √
/MAT/LAW22 (DAMA) √ √ √ √ √ √ √ √ √ √
/MAT/LAW23 (PLAS_DAMA) √ √ √ √ √ √ √ √ √ √
/MAT/LAW24 (CONC) √ √ √ √ √ √ √
/MAT/LAW26 (SESAM) √ √ √
/MAT/LAW28 (HONEYCOMB) √ √ √ √ √ √
USER1 √ √ √ √ √ √ √ √ √ √ √ √
USER2 √ √ √ √ √ √ √ √ √ √ √ √
USER3 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW32 (HILL)
/MAT/LAW33 (FOAM_PLAS) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW34 (BOLTZMAN) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW35 (FOAM_VISC) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW36 (PLAS_TAB) √ √ √ √ √ √ √ √ √ √
/MAT/LAW37 (BIPHAS) √ √ √
/MAT/LAW38 (VISC_TAB) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW40 (KELVINMAX) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW41 (LEE_TARVER) √ √ √ √ √
/MAT/LAW42 (OGDEN) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW44 (COWPER) √ √ √ √ √ √ √ √ √ √
/MAT/LAW46 (LES_FLUID) √
/MAT/LAW48 (ZHAO) √ √ √ √ √ √ √ √ √ √
/MAT/LAW49 (STEINB) √ √ √ √ √ √ √ √ √ √
/MAT/LAW50 (VISC_HONEY) √ √ √ √ √ √ √
/MAT/LAW51 (MULTIMAT) √ √ √
/MAT/LAW52 (GURSON) √ √ √ √ √ √ √ √ √ √
/MAT/LAW53 (TSAI_TAB) √ √ √ √ √ √ √
/MAT/LAW54 (PREDIT)
/MAT/LAW58 (FABR_A)
/MAT/LAW59 (CONNECT) √ √
/MAT/LAW60 (PLAS_T3) √ √ √ √ √ √ √ √ √ √
/MAT/LAW62 (VISC_HYP) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW63 (HANSEL)
/MAT/LAW65 (ELASTOMER) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW66 √ √ √ √ √ √ √ √ √ √
/MAT/LAW68 (COSSER) √ √ √ √ √ √ √
/MAT/LAW69 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW70 (FOAM_TAB) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW71 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW72 (HILL_MMC) √ √ √ √ √ √ √
/MAT/LAW73
/MAT/LAW74 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW75 (POROUS) √ √ √
/MAT/LAW76 (SAMP) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW77 √ √
/MAT/LAW78 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW79 (JOHN_HOLM) √ √ √ √ √ √ √ √ √
/MAT/LAW80
/MAT/LAW81 (DPRAG_CAP) √ √ √ √ √ √ √ √ √ √
/MAT/LAW82 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW83 √ √
/MAT/LAW84 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW88 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW90 √ √ √ √ √
/MAT/LAW92 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW94 (YEOH) √ √ √ √ √ √ √ √
/MAT/LAW95 (BERGSTROM_BOYCE) √ √ √ √ √ √
/MAT/LAW97 (JWLB) √ √ √
/MAT/LAW100 (MNF) √ √ √ √ √ √
/MAT/LAW101 √ √ √ √ √ √
/MAT/LAW102 (DPRAG2) √ √ √ √ √ √ √ √ √ √
/MAT/LAW103 (HENSEL-SPITTEL) √ √ √ √ √
/MAT/LAW104 (JOHNS_VOCE_DRUCKER) √ √ √ √
/MAT/LAW106 (JCOOK_ALM) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW109 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW111 √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW112 (PAPER or XIA) √ √ √ √ √ √ √ √ √ √
/MAT/LAW115 (DESHFLECK) √ √ √ √ √ √ √ √
/MAT/LAW116 √ √
/MAT/LAW117 √
/MAT/LAW120 (TAPO) √ √ √ √ √ √ √ √ √ √
/MAT/LAW121 (PLAS_RATE) √ √ √ √ √ √ √ √ √
/MAT/LAW122 (MODIFIED_LADEVEZE) √ √ √ √ √ √ √ √ √
/MAT/LAW124 (CDPM2) √ √ √ √ √ √ √ √ √
/MAT/LAW126 (JOHNSON_HOLMQUIST_CONCRETE) √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW127 (ENHANCED_COMPOSITE) √ √ √ √ √ √ √ √ √ √
/MAT/LAW133 (GRANULAR) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW134 (VISCOUS_FOAM) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW151 (MULTIFLUID) √ √ √ √ √
/MAT/LAW163 (CRUSHABLE_FOAM) √ √ √ √ √ √ √ √ √ √ √ √
/MAT/LAW169 (ARUP_ADHESIVE) √
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
SPH, 2D, Beam, Spring, CFD
Law Name SPH 2D ANALYSIS TRUSS BEAM Spring CFD
Type 36 Type 23 Type 15
/MAT/LAW1 (ELAST) √ √ √ √*
/MAT/LAW2 (PLAS_JOHNS) √+ √ √ √
/MAT/LAW3 (HYDPLA) √+ √
/MAT/LAW4 (HYD_JCOOK) √+ √
/MAT/LAW5 (JWL) √ √
/MAT/LAW6 (HYDRO or HYD_VISC) √+ √
/MAT/K-EPS √
/MAT/B-K-EPS √
/MAT/LAW12 (3D_COMP) √+
/MAT/LAW15 (CHANG)
/MAT/LAW16 (GRAY) √
/MAT/LAW19 (FABRI)
/MAT/LAW21 (DPRAG) √+ √
/MAT/LAW24 (CONC) √***+ √
/MAT/LAW25 (COMPSH)
/MAT/LAW26 (SESAM)
USER1 √
USER2 √
USER3 √
/MAT/LAW32 (HILL) √
/MAT/LAW34 (BOLTZMAN) √ √ √ √**
/MAT/LAW36 (PLAS_TAB) √+ √ √**
/MAT/LAW48 (ZHAO) √
/MAT/LAW49 (STEINB) √+ √
/MAT/LAW54 (PREDIT) √
/MAT/LAW58 (FABR_A)
/MAT/LAW63 (HANSEL)
/MAT/LAW66 √ √
/MAT/LAW68 (COSSER)
/MAT/LAW69 √
/MAT/LAW71 √ √**
/MAT/LAW73
/MAT/LAW74 √
/MAT/LAW76 (SAMP) √
/MAT/LAW77
/MAT/LAW78 √ √
/MAT/LAW80
/MAT/LAW81 (DPRAG_CAP) √+
/MAT/LAW82 √
/MAT/LAW83
/MAT/LAW84 √
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW94 (YEOH)
/MAT/LAW100 (MNF)
/MAT/LAW108 (SPR_GENE) √
/MAT/LAW109 √
/MAT/LAW111
/MAT/LAW113 (SPR_BEAM) √
/MAT/LAW114 (SPR_SEATBELT) √
/MAT/LAW116
/MAT/LAW117
/MAT/LAW120 (TAPO)
/MAT/LAW124 (CDPM2)
/MAT/LAW200 (MDS)
/MAT/USERij √**** √
/NONLOCAL/MAT
/VISC/LPRONY
/VISC/PRONY
Yes
blank
No
Only for TYPE3
Only for TYPE18 (integrated beam)
LAW24 is compatible with SPH, but not for feature with reinforcement
Isotropic laws only
Compatible with Sol2SPH formulation
