/MAT/LAW104 (JOHNS_VOCE_DRUCKER)
Block Format Keyword An elasto-plastic constitutive material law using the 6th order Drucker model with a mixed Voce and linear hardening.
Dependence on the Johnson-Cook strain rate and thermal softening effects due to self-heating can also be modeled. The law is available for isotropic shell and solid elements.
| /MAT/LAW104/mat_ID/unit_ID or /MAT/JOHNS_VOCE_DRUCKER/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | Ires | ||||||||
| H | Q | B | CDR | ||||||
| CJC | Fcut | ||||||||
| Tref | Tini | ||||||||
| Cp | |||||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| E | Young‘s
modulus. (Real) |
| Poisson’s
ratio. (Real) |
| Ires | Resolution method for plasticity.
(Integer) |
| Initial yield
stress. (Real) |
| H | Linear hardening
module. (Real) |
| Q | Voce hardening
coefficient. (Real) |
| B | Voce hardening
exponent. (Real) |
| CDR | Drucker
| CJC | Johnson-Cook strain rate
| Inviscid limit for the plastic
strain rate. (Real) |
| Fcut | Plastic strain rate filtering
frequency. Default = 10 kHz (Real) |
| Temperature softening
slope. (Real) |
| Tref | Reference temperature at which the
hardening law was identified in experiment. (Real) |
| Tini | Initial temperature of material in
simulation. (Real) |
| Taylor-Quinney
| Cp | Specific heat. (Real) |
| Plastic strain rate at isothermic
conditions. (Real) |
| Plastic strain rate at adiabatic
Example (Steel)
/UNIT/123
Example unit
Mg mm s
/MAT/LAW104/1/123
DP450 Steel
# Init. dens. Ref. dens.
7.85E-9 0
# E Nu Ires
194200.0 0.3 1
# YLD0 H Qvoce Bvoce Cdrucker
282.972 587.291 208.273 23.869 1.45
# JCcoef epsp0 Fcut
0.0236071 3.61e-3 10000.0
# Mu Tref Tini
1.335e-3 20.0 20.0
# ETA CP EPSP_IT EPSP_AD
0.9 0.42E9 0.002 0.04
#ENDDATA
/END
- The law uses 6th
order Drucker equivalent stress definition:
Where, and are respectively the second and third invariant of the deviatoric stress tensor .
The parameter CDR is user-defined and allows you to define several yield surfaces (Figure 1). To respect the convexity, its value must respect -27/8 ≤ CDR ≤ 2.25.Figure 1. Drucker yield surfaces
- The yield function is
defined as:
and
Where,- Initial yield stress.
- H
- Linear hardening.
- Voce hardening parameters.
- Johnson-Cook strain rate coefficient.
- Filtered plastic strain-rate.
- Inviscid limit plastic strain rate.
- Thermal softening slope.
The evolution of this flow stress equation with plasticity.Figure 2. Flow stress evolution with plasticity
- If
/HEAT/MAT is not used for this material, the
temperature is calculated internally using the incremental
formula:Where,
- Taylor-Quinney coefficient that must respect .
- Coefficient that defines the transition between isothermal and adiabatic conditions (Figure 3).
Figure 3. Evolution of the temperature weight with the plastic strain rate
