/MAT/LAW23 (PLAS_DAMA)
Block Format Keyword This law models an isotropic elastic plastic material and combines Johnson-Cook material model with a generalized damage model. The law is applicable only for solid elements.
| /MAT/LAW23/mat_ID/unit_ID or /MAT/PLAS_DAMA/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | |||||||||
| a | b | n | |||||||
| c | ICC | ||||||||
| Et | |||||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| E | Young's
modulus. (Real) |
| Poisson's
ratio. (Real) |
| a | Plasticity yield stress -
should be strictly positive. (Real) |
| b | Plasticity hardening
parameter. (Real) |
| n | Plasticity hardening
exponent. 3 (Real) |
| Failure plastic
strain. Default = 1030 (Real) |
| Plasticity maximum
stress. Default = 1030 (Real) |
| c | Strain rate coefficient.
Default = 0.00 (Real) |
| Reference strain
rate. If , no strain rate effect. (Real) |
| ICC | Strain rate computation
flag. 5
(Integer) |
| Damage model starts at
. Default = 0.15 (Real) |
| Et | Softening damage slope (
). Default = 0.00 (Real) |
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/LAW23/1/1
Alu
# RHO_I
.0027
# E nu
70000 .3
# a b n Eps_max sig_max0
100 0 1 .2 100
# c EPS_0 ICC
0 0 0
# EPS_dam E_t
.1 -2000
#ENDDATA
/END
- The damage law is applied to the stress tensor and damage occurs in tension, compression and shear.
- The input is the same as material law (/MAT/LAW22 (DAMA)).
- The plasticity hardening exponent n must be less than one.
- When reaches , in one integration point, then the solid element is deleted.
- ICC is a flag of the strain
rate effect on material maximum stress
