2025
View new features for Radioss 2025.
Current Radioss format uses the 12x extension format.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
The .h3d file is a compressed binary file, containing both model and result data. It can be used to post-process results in HyperView.
The RunnameAnnn file is a binary file, containing both model and result data. It can be used to post-process results in HyperView.
ASCII Output files are formatted output files from Radioss Starter and Radioss Engine.
The optional control file is used to get information about a currently running analysis.
When computing eigen modes using Radioss (/EIG), for example to create an input file for a flexible body, CPU time and memory requirements can be greatly reduced if a set of approximated modes is already available.
