.h3d Output File
The .h3d file is a compressed binary file, containing both model and result data. It can be used to post-process results in HyperView.
File Creation
The .h3d file is created after a Radioss Engine
run by translating the RunnameAnnn files through
hvtrans
. The Radioss script
automatically takes care of this.
File Contents
The .h3d file contains node and element definitions in addition to the
following results:
- Result
- Description
- Vector Data
- Velocities, displacements, accelerations, contact forces, internal forces, external forces, forces and moments for rigid bodies, rigid walls and sections, rotational velocities, fluid velocities (for incompressible fluid flow by BEM).
- Element Data
- Spring damage, density, energy, plastic strain, equivalent strain rate, failed layers, hourglass energy, pressure, stress tensor, temperature, thickness, von Mises stress, user law results.
- Nodal Mass
- Nodal mass results.
- Nodal Data
- Time step, mass variation, added inertia per node.
