Flexible Body Input File
OAFormulation
The total displacement field μ for every point of a flexible body is obtained from the displacement of a local frame defining the rigid motion of the body and from an additional local displacement field w L corresponding to the small vibrations of the body.
flexible_body2
( G 0 , G 1 , G 2 , and G 3 ) defines the global frame ( e 1 , e 2 , and e 3 ).
( L 0 , L 1 , L 2 , and L 3 ) defines an orthonormal local frame.
P is the rotation matrix from ( G 0 , G 1 , G 2 , and G 3 ) to ( L 0 , L 1 , L 2 , and L 3 ).
The total displacement, u , can thus be expressed as:
u = X u L 1 + Y u L 2 + Z u L 3 + ( 1 X Y Z ) u L 0 + P w L = u R + P w L
Where, u L 0 , u L 1 , u L 2 , and u L 3 are displacements of points L 0 , L 1 , L 2 , and L 3 , respectively,
X , Y , and Z are coordinates in the local frame ( L 0 , L 1 , L 2 , and L 3 )
u R is the rigid body contribution to the total displacement
Local displacement is given by a combination of local vibration modes Φ L i :
w L = Φ L α
Where, α is the vector of local modal contributions.
Rigid body displacement u R can also be expressed as a combination of 12 modes:
u R = Φ R ( u L 1 1 , u L 1 2 , u L 1 3 , u L 2 1 , u L 2 2 , u L 2 3 , u L 3 1 , u L 3 2 , u L 3 3 , u L 0 1 , u L 0 2 , u L 0 3 ) T
Where the projection modes Φ R i are obtained from the local coordinates:
Φ R 1 = X e 1 Φ R 2 = X e 2 Φ R 3 = X e 3 Φ R 4 = Y e 1 Φ R 5 = Y e 2 Φ R 6 = Y e 3 Φ R 7 = Z e 1 Φ R 8 = Z e 2 Φ R 9 = Z e 3 Φ R 10 = ( 1 X Y Z ) e 1 Φ R 11 = ( 1 X Y Z ) e 2 Φ R 12 = ( 1 X Y Z ) e 3
The choice of the local frame ( L 0 , L 1 , L 2 , and L 3 ) is fully arbitrary. These points do not need to be input explicitly. Their locations define local coordinates and thus, the components of the modes Φ R i .
If the flexible body contains elements with rotational DOF, three additional modes must be added to the Φ R i family, accounting for the inertia associated with these DOF. The components of these additional modes on each node of the flexible body having rotational DOF are:
Φ R 13 = [ 0 0 0 1 0 0 ] Φ R 14 = [ 0 0 0 0 1 0 ] Φ R 15 = [ 0 0 0 0 0 1 ]
