/TIMEOUT
Multi-Domain Keyword Allows you to specify the value of the timeout parameter for the establishment of the connection between RAD2RAD and Radioss Engine.
/TIMEOUT/Val
Definition
Val Value in seconds
Default = 20 seconds
  1. The timeout is used to prevent the RAD2RAD executable to wait infinitely for a connection if one or more Radioss Engine executables are missing.
