/MAT/LAW2 (PLAS_JOHNS)
Block Format Keyword This law represents an isotropic elasto-plastic material using the Johnson-Cook material model.
This model expresses material stress as a function of strain, strain rate and temperature. A built-in failure criterion based on the maximum plastic strain is available. For Solid and SPH elements, this material may account for the nonlinear dependence between pressure and density when corresponding Equation of State is prescribed.
/MAT/LAW2/mat_ID/unit_ID or /MAT/PLAS_JOHNS/mat_ID/unit_ID
mat_title
ρ i
E ν Iflag VP Pmin
If Iflag=0, insert the next line with classic input:
a b n ε p m a x σ max 0
If Iflag=1, insert the next line with simplified input:
σ y UTS ε U T S ε p m a x σ max 0
c ε ˙ 0 ICC Fsmooth Fcut Chard
m Tmelt ρ C p Tr Tmax
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
Iflag Input type flag. 3
=0 (Default)
Classic input for Johnson-Cook using parameters a, b, and n.
=1
Simplified input type using σ y , UTS, and ε U T S .
(Integer)
VP Formulation for rate effects.
= 0
Set to 2.
= 1
Plastic strain rate.
= 2 (Default)
Total strain rate.
= 3
Deviatoric strain rate.
(Integer)
Pmin Pressure cutoff (< 0).
Default = -1020 (Real)
[ Pa ]
a Yield stress. 2
(Real)
[ Pa ]
b Plastic hardening parameter b.
(Real)
[ Pa ]
n Plastic hardening exponent n. 6
Default = 1.0 (Real)
ε p m a x Failure plastic strain.
Default = 1020 (Real)
σ max 0 Maximum stress.
[ Pa ]
σ y Yield stress.
(Real)
[ Pa ]
UTS Ultimate tensile stress (engineering stress). Input U T S > σ y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyvaiaads facaWGtbGaeyOpa4Jaeq4Wdm3aaSbaaSqaaiaadMhaaeqaaaaa@3C76@ .
(Real)
[ Pa ]
ε U T S Engineering strain at UTS.
c Strain rate coefficient c 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbGaey yzImRaaGimaaaa@3AD0@ .
=0
No strain rate effect.
Default = 0.00 (Real)
ε ˙ 0 Reference strain rate.
If ε ˙ ε ˙ 0 , no strain rate effect.
(Real)
[ 1 s ]
ICC Strain rate computation flag. 9
= 0
Set to 1.
= 1 (Default)
Strain rate effect on σ max
= 2
No strain rate effect on σ max
(Integer)
Fsmooth Strain rate smoothing flag.
= 0
Set to 1.
= 1 (Default)
Strain rate smoothing is active.
(Integer)
Fcut Cutoff frequency for strain rate smoothing. Only available for shell and solid elements, Appendix: Filtering.
[Hz]
Chard Hardening coefficient (unloading).
= 0 (Default)
Isotropic model.
= 1
Kinematic Prager-Ziegler model.
= value between 0 and 1
Hardening behavior is interpolated between the two models. 15
(Real)
m Temperature exponent.
Default = 1.00 (Real)
Tmelt Melting temperature.
[ K ]
ρ C p Specific heat per unit volume. 13
(Real)
[ J m 3 K ]
Tr Reference temperature. 13
Default = 300 K (Real)
[ K ]
Tmax Maximum temperature.
[ K ]
Example (Classic Parameter Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
#              RHO_I
              7.8E-9
#                  E                  Nu     Iflag    flagVP                Pmin
              210000                  .3         0         1                   0
#                  a                   b                   n             EPS_max            SIG_max0
                 270               450.0                 0.6                   0                   0
#                  c           EPS_DOT_0       ICC   Fsmooth               F_cut               Chard
                0.10                   1         0         0                   0                   0
#                  m              T_melt              rhoC_p                 T_r                Tmax
                   0                   0                   0                   0                   0
#ENDDATA
/END
Example (Simplified Input - Experimental Data)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel (use ultimate tensile stress(UTS) and engineering strain )
#              RHO_I
              7.8E-9
              210000                  .3         1         1                   0
#              SIG_y                 UTS             EPS_UTS             EPS_max            SIG_max0
                 270               362.8              0.2885                   0                   0
                 0.1                   1         0         0                   0                   0
                   0                   0                   0                   0                   0
#ENDDATA
/END
  1. This is an elasto-plastic material model that includes strain rate and temperature effects with true stress and strain output.
  2. In this model the material behaves as a linear-elastic material when the equivalent stress is lower than the plastic yield stress. For higher stress values, the material behavior is plastic, and the true stress is calculated as:
    σ = ( a + b ε p n ) ( 1 + c ln ε ˙ ε ˙ 0 ) ( 1 ( T ) m )
    Where,
    T * = T T r T m e l t T r
    ε p
    Plastic strain
    ε ˙
    Strain rate
    T
    Temperature
    Tr
    Ambient temperature
    Tmelt
    Melting temperature
  3. If Iflag=0, the Johnson-Cook equation parameters a, b, and n values are entered.
    If Iflag=1, experimental engineering stress and stain data can be entered for σ y , UTS and ε U T S and the parameters a, b and n are calculated and printed in the Starter output file. If the a, b and n parameters cannot be automatically fit, then a Starter warning message will contain important information about changes to the material input.
  4. The plastic yield stress should always be greater than zero. To model pure elastic behavior, the plastic yield stress should be set to 1020.
  5. When ε p reaches the value of ε p m a x in one integration point, then based on the element type:
    • Shell elements: The corresponding shell element is deleted.
    • Solid elements: The deviatoric stress of the corresponding integral point is permanently set to 0; however, the solid element is not deleted.
  6. The plastic hardening exponent, n must be less than or equal to 1.
  7. The strain rate has no effect on truss elements.
  8. To eliminate the effect of the strain rate, you can either set the value of c equal to 0 or the reference strain rate ( ε ˙ 0 ) can be set equal to 1020. There is no effect of strain rate when ε ˙ is less than ε ˙ 0 .
  9. The ICC flag defines the effect of strain rate on the maximum material stress σ max . Figure 1 shows the value of for σ max the corresponding ICC flag.
    σ = ( a + b ε p n ) ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ = ( a + b ε p n ) ( 1 + c ln ( ε ˙ ε ˙ o ) )
    σ max = σ max 0 ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ max = σ max 0
  10. There is no effect of temperature on trusses. Beam element (with /PROP/TYPE3 or /PROP/TYPE18) together with /HEAT/MAT or /THERM_STRESS/MAT could consider thermal effect.
  11. The temperature is constant ( T = T r ), if ρ C p = 0 .
  12. Adiabatic conditions are assumed for thermal simulations with initial temperature equal to reference temperature (Tr) and:
    T = T r + Q ρ C p ( V o l u m e )
    Where, Q = Σ Δ E is the plastic energy increment with Δ E = σ · δ ε p .
  13. When /HEAT/MAT references this material model, the values of Tr, Tmelt and ρ C p defined in this card will be overwritten by the corresponding T 0 , T 1 and ρ 0 C p defined in /HEAT/MAT.
  14. When the temperature is not initialized using /HEAT/MAT or /INITEMP, the reference temperature (Tr) is also the initial temperature.
  15. The hardening coefficient is used to describe the hardening model (during unloading). The values of the hardening coefficient should be between 0 and 1.
  16. By default, the hydrostatic pressure is linearly proportional to the density:
    P = K μ
    Where,
    K = E 3 1 - 2 v
    Bulk modulus
    μ = V 0 V - 1 = ρ ρ 0 - 1
    An additional Equation of State (/EOS) card can refer to this material in order to define a nonlinear dependency between hydrostatic pressure and volumetric strain.
    This behavior is only available for solid and SPH elements.
