Block Format Keyword Non-local regularization for elasto-plastic failure criteria (as in, dependent to plastic
strain) and shell thickness variation.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
/NONLOCAL/MAT/mat_ID/unit_ID
Definition
Field
Contents
SI Unit Example
mat_ID
Material identifier.
(Integer,
maximum 10 digits)
unit_ID
Unit identifier.
(Integer, maximum 10 digits)
Non-local internal
length.
(Real)
Mesh convergence element length
target.
(Real)
The non-local regularization is used to get mesh independent results
(size, orientation) in case of instabilities such as failure and/or
thickness variation (for shells). The mesh independent results imply a mesh
convergence for mesh sizes less than or equal to the maximum value you
set, . This maximum mesh size is then the highest mesh size used for which
results are mesh convergent.
The non-local formulation is compatible with
elasto-plastic material laws only. When activated, the computation of
the attached failure criteria based on plastic strain and/or the shell
thickness variation depends on a regularized nodal "non-local" plastic
strain calculated on the entire mesh. The non-local plastic strain at
nodes denoted is computed accounting for its own
gradient and its local counterpart is computed at the Gauss points following the set of
equations:
The parameters and are automatically set. You have to set the parameter (or , Comment 2) which defines a non-local "internal
length" corresponding to a radius of influence in the non-local variable
computation. This defines the size of the non-local regularization band (Figure 1). Figure 1. Non-local regularization principle
illustration
The failure criterion damage variable is then computed
using the non-local plastic strain.
Where, is the plastic strain at failure
depending on the failure criterion formulation.
To set the non-local
length parameter , you can select:
Directly input the value of in the input card if a direct
control on this parameter is needed. In this case, the parameter must be ignored.
Input the maximum mesh size for which results are mesh
convergent. The non-local regularization will then be effective for
all mesh sizes such as . In this case, an automatic set of is realized according to the value
of , and the input value of is ignored.
For instance, if you
want converged and mesh-independent results for a mesh size of
5mm, mm. In this case, the results
will be converged, mesh-size and mesh orientation independent
for mm.
When the non-local regularization is used for shell elements, an
additional regularization is made on the thickness variation computation
avoiding an additional localization issue. In the common local case (Figure 2), the compatibility of thickness
between shell elements is not ensured, due to the lack of kinematic
equations in the z-direction, and the thickness variation is locally
computed at Gauss points. By introducing the non-local plastic strain in the
"in-thickness" strain increment, the compatibility is restored (Figure 3).
Note: This last point implies that the identified
parameters can be used on solid and shells, as results will be identical
within the same range of stress triaxiality .
Note: The method is not yet compatible with quadratic elements /TETRA10 and /BRIC20.
List of compatible material laws for shells thickness variation
regularization:
/MAT/LAW2 (PLAS_JOHNS)
/MAT/LAW22 (DAMA)
/MAT/LAW27 (PLAS_BRIT)
/MAT/LAW32 (HILL)
/MAT/LAW36 (PLAS_TAB)
/MAT/LAW43 (HILL_TAB)
/MAT/LAW44 (COWPER)
/MAT/LAW48 (ZHAO)
/MAT/LAW57 (BARLAT3)
/MAT/LAW60 (PLAS_T3)
/MAT/LAW63 (HANSEL)
/MAT/LAW64 (UGINE_ALZ)
/MAT/LAW72 (HILL_MMC)
/MAT/LAW76 (SAMP)
/MAT/LAW78
/MAT/LAW87 (BARLAT2000)
/MAT/LAW93 (ORTH_HILL)
(CONVERSE)
/MAT/LAW104 (JOHNS_VOCE_DRUCKER)
/MAT/LAW109
/MAT/LAW110 (VEGTER)
/MAT/LAW121 (PLAS_RATE)
/MAT/LAW126
(JOHNSON_HOLMQUIST_CONCRETE)
List of elasto-plastic failure model and coupled damage model
compatible with non-local regularization:
MMC damage model in /MAT/LAW72
Damage model in /MAT/LAW76
/FAIL/BIQUAD
/FAIL/COCKROFT
/FAIL/EMC
/FAIL/HC_DSSE (for shells)
/FAIL/INIEVO
/FAIL/JOHNSON
/FAIL/ORTHBIQUAD
/FAIL/RTCL
/FAIL/SPALLING
/FAIL/SYAZWAN
/FAIL/TAB1
/FAIL/TAB2
/FAIL/USERi
/FAIL/WIERZBICKI
/FAIL/WILKINS
List of material laws with non-local regularized temperature computation:
/MAT/LAW109
Two additional specific
outputs, non-local plastic strain (NL_EPSP) and non-local
plastic strain rate (NL_EPSD) are available in ANIM and
H3D files. These are also available in time histories with
NL_PLAS and NL_EPSD for shells and
NL_PLAS and NL_PLSR for solids,
respectively. For more information, refer to Output Database.
1 Valentin Davaze, Sylvia
Feld-Payet, Nicolas Vallino, Bertrand Langrand, Jacques Besson,A non-local
approach for Reissner–Mindlin shell elements in dynamic simulations: Application
with a Gurson model, Computer Methods in Applied Mechanics and
Engineering 415 (2023), 116142, ISSN 0045-7825.
2 Valentin Davaze, Nicolas
Vallino, Bertrand Langrand, Jacques Besson, Sylvia Feld-Payet,A non-local
damage approach compatible with dynamic explicit simulations and parallel
computing, International Journal of Solids and Structures 228 (2021),
110999, ISSN 0020-7683.
3 Valentin Davaze, Numerical modelling of crack initiation and
propagation in ductile metallic sheets for crash simulations. Mechanics
of materials. University Paris sciences et lettres, 2019. English.
