/PROP/TYPE1 (SHELL)
Block Format Keyword Describes the shell property set which is used for 3-node or 4-node shell element. Belytschko, QBAT or QEPH shell formulation are available.
/PROP/TYPE1/prop_ID/unit_ID or /PROP/SHELL/prop_ID/unit_ID
prop_title
Ishell Ismstr Ish3n Idrill P_thickfail
hm hf hr dm dn
N Thick Ashear Ithick Iplas Ipos
Definition
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
prop_title Property title.
Ishell 4 node shell element formulation flag.
= 0
Use value in /DEF_SHELL.
= 1 Default, if /DEF_SHELL is not defined
Q4, visco-elastic hourglass modes orthogonal to deformation and rigid modes (Belytschko).
= 2
Q4, visco-elastic hourglass without orthogonality (Hallquist).
= 3
Q4, elasto-plastic hourglass with orthogonality.
= 4
Q4 with improved type 1 formulation (orthogonalization for warped elements).
= 12
QBAT shell formulation.
= 24
QEPH shell formulation.
(Integer)
Ismstr Shell small strain formulation flag. 4
= -1
Automatically set the best value according to element type and material law.
= 0
= 1
Small strain from time = 0 (formulation compatible with all other formulation flags).
= 2 Default, if /DEF_SHELL is not defined
Full geometric nonlinearities with possible small strain formulation activation in Radioss Engine (option /DT/SHELL/CST).
= 3
Old small strain formulation (only compatible with Ishell = 2).
= 4
Full geometric nonlinearities (in Radioss Engine, option /DT/SHELL/CST has no effect).
= 10
Lagrange type total strain for hyperelastic material laws.
(Integer)
Ish3n 3 node shell element formulation flag.
= 0
= 1
Standard triangle (C0).
Standard triangle (C0) with modification for large rotation.
= 30
DKT18.
= 31
DKT_S3, which based on DTK12 of BATOZ (refer to the Element Library in the Theory Manual).
(Integer)
Idrill Drilling degree of freedom stiffness flag. 3
= 0
= 1
Yes.
No.
(Integer)
P_thickfail Fraction of failed thickness for shell element deletion. 11
-1.0 ≤ P_thickfail ≤ 0
Fraction of failed integration point through thickness.
0.0 ≤ P_thickfail ≤ 1.0
Fraction of failed thickness.
Default = 1.0 (Real)
hm Shell membrane hourglass coefficient. 5
Only used when Ishell=1, 2, 3, 4.
Default = 0.01 for Ishell =1, 2, 4.
Default = 0.1 for Ishell =3.
(Real)
hf Shell out-of-plane hourglass. 5
Only used when Ishell =1, 2, 3, 4.
Default = 0.01 (Real)
hr Shell rotation hourglass coefficient. 5
(Real)
dm Shell Membrane Damping
For default values, refer to the table in Comment 7.
(Real)
dn Shell numerical damping. 6
It is only used for Ishell =12, 24 and Ish3n =30
Default =0.015 for Ishell =24 (QEPH)
Default =0.001 for Ishell =12 (QBAT)
Default =0.0001 for Ish3n =30 (DKT18)
(Real)
N Number of integration points through the thickness with 0 < N < 10. 10
= 0 (Default)
Means global integration model for material LAW1, and automatically set N =3 for other material laws.
= 1
Membrane behavior.
(Integer)
Thick Shell thickness.
(Real)
[ m ]
Ashear Shear factor.
Default is Reissner value: 5/6 (Real)
Ithick Shell resultant stresses calculation flag. 8
= -1
= 0
= 1
Thickness change is taken into account.
Thickness is constant.
(Integer)
Iplas Shell plane stress plasticity flag for material laws 2, 22, 27, 32 and 36. This flag is not used for the other material laws. 9
= -1
= 0
= 1
Iterative projection with three Newton iterations.
Radial return.
(Integer)
Ipos Mid shell positioning flag. 12
= 0 (Default)
No shell offset.
= 3
The upper surface is coincident with the element mid-surface.
= 4
The lower surface is coincident with the element mid-surface.
(Integer)
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
#              MUNIT               LUNIT               TUNIT
                  kg                  mm                  ms
#-  2. GEOMETRICAL SETS:
/PROP/SHELL/1/2
Shell_1mm
#   Ishell    Ismstr     Ish3n    Idrill                            P_thick_fail
        24         0         0         0                                       0
#                 hm                  hf                  hr                  dm                  dn
                   0                   0                   0                   0                   0
#        N   Istrain               Thick              Ashear              Ithick     Iplas      Ipos
         5         0                   1                   0                   1         1         0
#enddata
  1. Ishell - Shell small strain formulation flag
    • Ishell =1,2,3,4 (Q4): original 4 node Radioss shell with hourglass perturbation stabilization
    • Ishell =24 (QEPH): formulation with hourglass physical stabilization for general use
    • Ishell =12 (QBAT): modified BATOZ Q4γ24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell
    • Ishell =2 is incompatible with one integration point (through thickness) for shell element
  2. Ish3n - 3 node shell element formulation flag
    • Ish3n =30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points
  3. Idrill - Drilling degree of freedom stiffness flag
    • Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems
    • Idrill is available for QEPH, QBAT (Ishell =12, 24), and standard triangle (C0) shell elements (Ish3n = 1, 2)
  4. Ismstr - Small strain formulation
    • Small strain formulation is activated from time t=0, if Ismstr =1 or 3. It may be used for a faster preliminary analysis, but the accuracy of the results is not ensured.
    • Any shell for which Δt < Δt min MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaqGuoGaae iDaiaayIW7caqG8aGaaGjcVlaabs5acaqG0bWaaSbaaSqaaiaab2ga caqGPbGaaeOBaaqabaaaaa@415B@ can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST; except if Ismstr =4.
    • If the small strain option is set to 1 or 3, the strains and stresses which are given in material laws, are engineering strains and stresses; otherwise they are true strains and stresses.
    • Ismstr =10 is only compatible with these material laws 42, 62, 69, and 82 that use total strain formulation. Generally, the Left Cauchy-Green strain is used. For User laws, the deformation gradient tensor and the right stretch tensor may be used.
  5. hm, hf, and hr - Hourglass coefficients
    • Are only used for Q4 shells (Ishell =1,2,3,4). They must have a value between 0 and 0.05.
    • For Ishell =3, the default values of hm and hr are 0.1 with larger values possible.
  6. dn - Shell numerical damping coefficient
    • dn is only used for Ishell =12, 24 and Ish3n =30
      • Ishell =24 (QEPH) dn is used for hourglass stress calculation
      • Ishell =12 (QBAT) dn is used for all stress terms, except transverse shear
      • Ish3n =30 (DKT18) dn is only used for membrane
  7. Default value for numerical damping coefficient dm.
    dm
    Ishell= 1, 2, 3, 4 (Q4) 0.05 for LAW27
    0.0 for LAW32, 36
    Ishell=12 (QBAT) 0.0 for LAW2, 27, 32, 36
    Ishell=24 (QEPH) 0.015 for all other material
    Ish3n= 1, 2, 31 0.0
    Ish3n=30 (DKT18) 0.0
    Any Ishell, Ish3n 0.05 for LAW65
  8. Ithick - Shell resultant stresses calculation flag
    • Ithick is automatically set to 1 for material LAW32
    • Ithick =1, the small strain option is automatically deactivated in the corresponding type of element
  9. Iplas - Shell plane stress plasticity flag
    • It is recommended to use Iplas = -1, if Ithick = -1.
    • If Iplas =1, the small strain option is automatically deactivated in the corresponding type of element
  10. Global integration, N=0
    • Global integration is only compatible with material LAW1.
    • Failure models are not available with global integration for shells.
    • State files (/STATE/DT which creates /INISHE and /INISH3N) are not compatible with global integration.
    • Automatically set to N=3 for the other material laws.
  11. Element deletion rules used with P_thickfail and failure models:
    • P_thickfail defined in both the property and in the failure model(s) (/FAIL) are considered to trigger the element failure.
      • P_thickfail > 0 defines a fraction of failed thickness. This uses the amount of thickness assigned to each integration point.
      • P_thickfail < 0 defines a ratio of failed integration points. This uses the number of integration point.
      • Minimum of the absolute value defined in the shell property or in the failure criterion card is used to trigger the element failure.
    • For fully-integrated shells (Ishell =12), the rules described above for under-integrated shells applies to each Gauss point separately. P_thickfail criterion is checked for all integration point thickness for each in-plane Gauss point. The element is deleted only when all Gauss points reach P_thickfail criterion.
    • P_thickfail defined in the property and in the failure model(s) (/FAIL) must use the same sign. Otherwise, the P_thickfail defined in the property takes the same sign as the value defined in the failure criterion card /FAIL.
    • P_thickfail rules are not used with failure models defined inside the material laws. It is used only for the failure model defined with /FAIL.
    • By default, P_thickfail =1.0 in the property.
  12. Ipos: Shell position or thickness offset:
    • Ipos =0: No shell offset
    • Ipos =3: The upper surface is coincident with the element mid-surface.
    • Ipos =4: The lower surface is coincident with the element mid-surface.
