RD-E: 2600 Ruptured Plate
A metallic thick plate is perforated by a rigid sphere. Simulation of the rupture uses different failure models.
Failure of a circular plate subjected to the impact of an infinite rigid sphere is studied. Material models, with or without a dedicated failure criteria, are compared. The new failure criteria available adds to the simple rupture models existing in such material laws as LAW2 and LAW27.
ex_26_rup_plate
The study is divided into three parts:
  • Rupture using a damage model in LAW27
  • Failure using the Johnson-Cook model
  • Advantage of Forming Limit Diagram as a failure model
The sensitivity of the results for the different failure models is demonstrated.
Examples
