The fluid-structure interaction and the fluid flow are studied in cases of a fuel tank sloshing and overturning. A
bi-phase liquid-gas material with an ALE formulation is used to define the interaction between water and air in the
fuel tank.
The purpose of this example is to study the energy propagation and the momentum transfer through several bodies, initially
in contact with each other, subjected to multiple impact. The process of collision and the energetic behavior upon
impact are described using a 3-dimensional mode.
The impact and rebound between balls on a small billiard table is studied. This example deals with the problem of
defining interfaces and transmitting momentum between the balls.
After a quasi-static pre-loading using gravity, a dummy cyclist rides along a plane, then jumps down onto a lower
plane. Sensors are used to simulate the scenario in terms of time.
The purpose of this study is to demonstrate the use of quadratic interface contact using two gears in contact with
identical pitch diameter and straight teeth. Two different contact interfaces are compared.
The crashing of a box beam against a rigid wall is a typical and famous example of simulation in dynamic transient
problems. The purpose for this example is to study the mesh influence on simulation results when several kinds of
shell elements are used.
A square plane subjected to in-plane and out-of-plane static loading is a simple element test. It allows you to highlight
element formulation for elastic and elasto-plastic cases. The under-integrated quadrilateral shells are compared with
the fully-integrated BATOZ shells. The triangles are also studied.
The modeling of a camshaft, which takes the engine's rotary motion and translates it into linear motion for operating
the intake and exhaust valves, is studied.
The ditching of an object into a pool of water is studied using ALE and SPH approaches. The simulation results are
compared to the experimental data and to the analytical results.
A rubber ring resting on a flat rigid surface is pushed down by a circular roller to produce self-contact on the inside
surface of the ring. Then the roller is simultaneously rolled and translated so that crushed ring rolls along the
flat surface.
Separate the whole model into main domain and sub-domain and solve each one with its own timestep. The new Multi-Domain
Single Input Format makes the sub-domain part definition with the /SUBDOMAIN keyword.
The aim of this example is to introduce /INIVOL for initial volume fractions of different materials in multi-material ALE elements, /SURF/PLANE for infinite plane, and fluid structure interaction (FSI) with a Lagrange container.
A heat source moved on one plate. Heat exchanged between a heatsource and a plate through contact, also between a
plate and theatmosphere (water) through convective flux.
Impacts of rotating structures usually happen while the structure is rotating at a steady state. When the structure is
rotating at very high speeds, it is necessary to include the centrifugal force field acting on the structure to correctly
account for the initial stresses in the structure due to rotation.
A beam frame receives an impact from a mass having initial velocity.
A beam frame with clamped extremities receives an impact at its mid-point from a pointed mass
having initial velocity. The material is subjected to the elasto-plastic law of
Johnson-Cook. The model is meshed with beam elements. An infinite rigid wall with
only one secondary node, including the impacted node, is subjected to the initial
velocity. This example is considered a dynamic problem and the explicit solver is
used.
The explicit approach leads to finding a quasi-static equilibrium of the structure after impact.
The impacting mass is simulated using a sliding rigid plane wall
(/RWALL) having an initial velocity of 10 ms-1and
a mass of 3000 g. Only one secondary node exists: the node O to simulate a point
impact.
Points A, F, F', D, E and E' are fully fixed.
Input Files
Before you begin, copy the file(s) used in this example to
your working directory.
The purpose of this example is to perform a static analysis using beam
elements.
A pointed mass (3 kg) makes an impact at point O of a beam frame (see Figure 4 for the geometry) using a speed of 10
ms-1in the Z direction. The beams are made of steel and each beam
section is square-shaped (each side being 6 mm long).
Dimensions are: AB = BC = CD = BE = BF = E'C = CF' = 90 mm.
Points A, D, E, F, E', and F' are fixed.
Beam Properties
Value
Cross section
36 mm2
Moments of inertia in Y and Z
108 mm4
Moments of inertia in X
216 mm4
The steel material used has the following properties:
Material Properties
Value
Density
0.0078
Young's modulus
200 000
Poisson's ratio
0.3
Yield stress
320
Hardening parameter
134.65
Hardening exponent
1.0
All other coefficients are set to default values. Plasticity is taken into account using LAW2
without failure.
Model Method
The mesh is a regular beam mesh, each beam being 9 mm long (total = 70 beams).
Results
Curves and Animations
The main results refer to the time history of points B and O with regard to displacements and
velocities.
