/INIVEL
Block Format Keyword Defines initial velocity on a group of nodes.
| /INIVEL/type/inivel_ID/unit_ID | |||||||||
| inivel_title | |||||||||
| VX | VY | VZ | grnd_ID | skew_ID | |||||
| Tstart | sens_ID | ||||||||
Definition
| type | Initial velocity type.
| inivel_ID | Initial velocity block
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| inivel_title | Initial velocity block
title. (Character, maximum 100 characters) |
| VX | X
velocity. (Real) |
or |
| VY | Y
velocity. (Real) |
or |
| VZ | Z
velocity. (Real) |
or |
| grnd_ID | Node group on which
specific initial velocities are applied. (Integer) |
| skew_ID | Skew
identifier. (Integer) |
| Tstart | Start time. Default = 0.0 (Real) |
| sens_ID | Sensor property identifier.
(Integer) |
- The grnd_ID input is obligatory. The initial velocities will only be applied to nodes belonging to a node group.
- Unit of velocity in translation is . In rotation, then angle is in unit and thus the velocity is in unit .
- Initial velocity is applied when time Tstart is reached or when the sensor is activated.
