/INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
/INITRUSS/FULL/unit_ID | |||||||||
truss_ID | prop_type | ||||||||
EINT | F | AREA |
Definition
unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
truss_ID | Element
identifier. (Integer) |
prop_type | Property
set. (Integer) |
EINT | Total internal
energy. (Real) |
F | Truss element normal
force. (Real) |
AREA | Cross-sectional area
of the truss. (Real) |
Plastic
strain. (Real) |
