- /INIBEAM
- /INIBRI
Describes the different initial state for a brick. The initial state for brick may be defined by more than one block.
- /INICRACK
Block Format Keyword Definition of the initial crack.
- /INIGRAV
Block Format Keyword Defines initial state from hydrostatic pressure due to gravity loading.
- /INIMAP1D
Block Format Keyword Map 1D velocities and thermodynamic values into 2D or 3D space using spherical, cylindrical, or planar mapping methods. The mapped results are used with /ALE/EULER materials.
- /INIMAP1D/FILE
- /INIMAP2D
Block Format Keyword Map 2D velocity and thermodynamic values into a 3D axi-symmetric space for use with /ALE/EULER materials.
- /INIMAP2D/FILE
- /INIQUA
Block Format Keyword Describes the different initial state for a quad element.
- /INISHE or /INISH3
- /INISPHCEL/FULL
Block Format Keyword Describes the initial state for a Smooth Particle Hydrodynamic (SPH).
- /INISPRI/FULL
Block Format Keyword Describes the initial state for spring elements. All values defined in this card will be applied at the beginning on the computation.
- /INISTA
Block Format Keyword Describes the initial state file.
- /INITEMP
Block Format Keyword Describes the initial nodal temperature.
- /INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
- /INIVEL
Block Format Keyword Defines initial velocity on a group of nodes.
- /INIVEL/AXIS
Block Format Keyword Initialize both translational and rotational velocities on a group of nodes in a given coordinate system.
- /INIVEL/FVM
Block Format Keyword Defines initial material velocities on a group of elements (bricks, quad or triangles) for the Finite Volume solver.
- /INIVEL/NODE
Block Format Keyword Initialize translational and rotational velocities on each node in the global or in a given coordinate system.
- /INIVOL
Block Format Keyword For multi-material ALE modeling, this initial condition defines the initial volumetric fractions on a side of a defined surface.
- /STATE/STR_FILE
Block Format Keyword Allows to read an initial state (blocks /INISHE, /INISH3, and /INIBRI) by specifying the name of a stress file possibly compressed using GZIP.
