/INISPRI/FULL
Block Format Keyword Describes the initial state for spring elements. All values defined in this card will be applied at the beginning on the computation.
| /INISPRI/FULL/unit_ID | |||||||||
| spring_ID | prop_type | nvars | |||||||
If prop_type = 4:
| FX | DX | FEPX | DPLX+ | DPLX- | |||||
| LX | EI | ||||||||
If prop_type = 12:
| LX | EI | DFS | |||||||
If prop_type = 26:
| FX | DX | FEPX | |||||||
| LX | EI | DV | |||||||
If prop_type = 8, 13, 25 and prop_type = 32
with material /MAT/LAW108 and
/MAT/LAW113:
| FY | DY | FEPY | DPLY+ | DPLY- | |||||
| FZ | DZ | FEPZ | DPLZ+ | DPLZ- | |||||
| MX | RX | MEPX | RPLX+ | RPLX- | |||||
| MY | RY | MEPY | RPLY+ | RPLY- | |||||
| MZ | RZ | MEPZ | RPLZ+ | RPLZ- | |||||
| LX | LY | LZ | EI | EDX | |||||
| EDY | EDZ | ERX | ERY | ERZ | |||||
If prop_type = 29, 30, 31, 32, 33, 35, 36, 44, 45, 46:
| FX | DX | ||||||||
| FY | DY | ||||||||
| FZ | DZ | ||||||||
| MX | RX | ||||||||
| MY | RY | ||||||||
| MZ | RZ | ||||||||
| EI | |||||||||
| V1 | V2 | VR3 | Vnvars | ||||||
Definition
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| spring_ID | Element
| prop_type | Property set. 2 (Integer, maximum 10 digits) |
| nvars | Number of user element
variables. (Integer, maximum 10 digits) |
| FX | Spring element force
along X direction. (Real) |
| FY | Spring element force
along Y direction. (Real) |
| FZ | Spring element force
along Z direction. (Real) |
| MX | Spring element moment
around X direction. (Real) |
| MY | Spring element moment
around Y direction. (Real) |
| MZ | Spring element moment
around Z direction. (Real) |
| DX | Spring element
elongation along X direction. (Real) |
| DY | Spring element
elongation along Y direction. (Real) |
| DZ | Spring element
elongation along Z direction. (Real) |
| RX | Spring element
rotation around X direction. (Real) |
| RY | Spring element
rotation around Y direction. (Real) |
| RZ | Spring element
rotation around Z direction. (Real) |
| FEPX | Spring elastic-plastic
force along X direction. (Real) |
| FEPY | Spring elastic-plastic
force along Y direction. (Real) |
| FEPZ | Spring elastic-plastic
force along Z direction. (Real) |
| MEPX | Spring elastic-plastic
moment around X direction. (Real) |
| MEPY | Spring elastic-plastic
moment around Y direction. (Real) |
| MEPZ | Spring elastic-plastic
moment around Z direction. (Real) |
| DPLX+ | Max displacement in
positive X direction. (Real) |
| DPLY+ | Max displacement in
positive Y direction. (Real) |
| DPLZ+ | Max displacement in
positive Z direction. (Real) |
| RPLX+ | Max rotation in
| RPLY+ | Max rotation in
| RPLZ+ | Max rotation in
negative X direction. (Real) |
negative Y direction. (Real) |
negative Z direction. (Real) |
| LX | Initial spring length
| LY | Initial spring length
| LZ | Initial spring length
| EDX | Deformation energy
| EDY | Deformation energy
| EDZ | Deformation energy
| ERX | Rotation energy around
| ERY | Rotation energy around
| ERZ | Rotation energy around
| DFS | Relative force between
pulley branches. 2 (Real) |
| DV | Spring velocity
filtering. 3 (Real) |
| EI | Total internal
energy. (Real) |
| VR1 | 1st user
variable value. (Real) |
| VR2 | 2nd user
| VR3 | 3rd user
| Vnvars | nvarsth user variable value.
4 (Real) |
- The initial state for spring may be defined by more than one block (for the same spring type only).
- The relative force between pulley branches, DFS, is available only for spring property /PROP/TYPE12 (SPR_PUL).
- Spring velocity filtering, DV, is available only for spring property TYPE26. It is based on strain rate filtering factor (ALPHA – see /PROP/TYPE26 (SPR_TAB)).
- The nvars is the number of the first user variables to be initialized for a spring. It must be less or equal to the total number of internal variables used in a user type law (NUVAR).
