/INISPHCEL/FULL
Block Format Keyword Describes the initial state for a Smooth Particle Hydrodynamic (SPH).
/INISPHCEL/FULL/unit_ID | |||||||||
node_ID | nvars | ||||||||
Eint | rho | h | |||||||
Epsp |
For the nvars auxiliary internal variables (3 per line)
V1 | V2 | V3 | |||||||
Etc. | Vnvars |
Definition
unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
node_ID | Supporting node
identifier. (Integer) |
nvars | Number of auxiliary internal
variables. (Integer) |
Eint | Internal energy
density. (Real) |
rho | Density. (Real) |
h | Smoothing
length. (Real) |
Stress in direction
1. (Real) |
Stress in direction
2. (Real) |
Stress in direction
3. (Real) |
Epsp | Plastic
strain. (Real) |
V1 to Vnvars | First to
nvarsth auxiliary variable
values (3 per line). (Real) |
- The initial state for SPH may be defined by more than one block.
- The unit translation will not be performed for auxiliary variable values.
