/INIVEL/FVM
Block Format Keyword Defines initial material velocities on a group of elements (bricks, quad or triangles) for the Finite Volume solver.
/INIVEL/FVM/inivel_ID/unit_ID
inivel_title
VX. VY. VZ grbric_ID grqd_ID grtria_ID skew_ID
Tstart sens_ID
Definition
inivel_ID Initial velocity block identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
inivel_title Initial velocity block title.
VX X velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VY Y velocity.
(Real)
VZ Z velocity.
(Real)
grbric_ID Brick group on which specific initial velocities are applied.
(Integer)
grqd_ID Quad groups on which specific initial velocities are applied.
(Integer)
grtria_ID Tria groups on which specific initial velocities are applied.
(Integer)
skew_ID Skew identifier.
(Integer)
Tstart Start time.
Default = 0.0 (Real)
[ s ]
sens_ID Sensor property identifier.
= 0
No sensor is used.
(Integer)
  1. At least one group ID must be provided.
  2. /INIVEL/FVM is used to initialize velocities in solid elements for the Finite Volume solver of /MAT/LAW151 (MULTIFLUID).
  3. Initial velocity is applied when time Tstart is reached or when the sensor is activated.
