2026
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Describes the different initial state for a brick. The initial state for brick may be defined by more than one block.
Block Format Keyword Definition of the initial crack.
Block Format Keyword Defines initial state from hydrostatic pressure due to gravity loading.
Block Format Keyword Map 1D velocities and thermodynamic values into 2D or 3D space using spherical, cylindrical, or planar mapping methods. The mapped results are used with /ALE/EULER materials.
Block Format Keyword Map 2D velocity and thermodynamic values into a 3D axi-symmetric space for use with /ALE/EULER materials.
Block Format Keyword Describes the different initial state for a quad element.
Block Format Keyword This option is used to initialize internal variables of user type material laws for shells (UVAR buffer).
Block Format Keyword Describes the initial plastic strain for a shell in each integration point.
Block Format Keyword Describes the failure criteria for a shell.
Block Format Keyword Describes the initialization of orthotropy direction for shells element per element.
Block Format Keyword This option is used to set a scale factor for yield stress per element for shells.
Block Format Keyword This describes the initial state for strain.
Block Format Keyword Describes the initialization strain for shell elements in the global coordinate system.
Block Format Keyword Describes the initial state of stress.
Block Format Keyword Describes the initialization of stress tensor given in global coordinate system for shell elements.
Block Format Keyword Describes the initialization of thickness for shells element per element.
Block Format Keyword Describes the initial state for a Smooth Particle Hydrodynamic (SPH).
Block Format Keyword Describes the initial state for spring elements. All values defined in this card will be applied at the beginning on the computation.
Block Format Keyword Describes the initial state file.
Block Format Keyword Describes the initial nodal temperature.
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
Block Format Keyword Defines initial velocity on a group of nodes.
Block Format Keyword Initialize both translational and rotational velocities on a group of nodes in a given coordinate system.
Block Format Keyword Defines initial material velocities on a group of elements (bricks, quad or triangles) for the Finite Volume solver.
Block Format Keyword Initialize translational and rotational velocities on each node in the global or in a given coordinate system.
Block Format Keyword For multi-material ALE modeling, this initial condition defines the initial volumetric fractions on a side of a defined surface.
Block Format Keyword Allows to read an initial state (blocks /INISHE, /INISH3, and /INIBRI) by specifying the name of a stress file possibly compressed using GZIP.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
