/INISHE/STRS_F or /INISH3/STRS_F
Block Format Keyword Describes the initial state of stress.
| /INISHE/STRS_F/unit_ID or /INISH3/STRS_F/unit_ID | |||||||||
| shell_ID | nb_integr | npg | Thick | ||||||
| H1 | H2 | H3 | |||||||
if nb_integr = 0
if nb_integr > 0
Definition
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| shell_ID | Element
identifier. (Integer) |
| nb_integr | Integration point number
through the thickness. (Integer) |
| npg | Number of surface
quadrature points.
(Integer) |
| Thick | Shell thickness. 8 (Real) |
| Total membrane
energy. (Real) |
| Total bending
energy. (Real) |
| H1 | Hourglass force. 3 (Real) |
| H2 | Hourglass force. 3 (Real) |
| H3 | Hourglass force. 3 (Real) |
| First plane
stress. (Real) |
| Second plane
stress. (Real) |
| Shear
stress. (Real) |
| Shear
stress. (Real) |
| Shear
stress. (Real) |
| Plastic
strain. (Real) |
| Bending
stress. (Real) |
| Bending
stress. (Real) |
| Bending
stress. (Real) |
- The nb_integr should be equal to the nb_integr defined in the shell property definition.
- The npg must be set according to the formulation which is used in the shell property
- The H1, H2 and H3 are read only when npg = 0 or npg = 1
- The bending stresses
are:Where,
- Length
- Thickness
- Moment
- For npg = 0 or 1 and nb_integr > 0, the optional continuation lines have to be repeated for each integration point.
- For
npg = 3 or 4, the optional continuation lines must be
repeated npg times for each integration point as:repeat for each integration point
- Line 7
- Line 8
- The initial state for shell may be defined by more than one block.
- The value given for thickness (Thick) will be used instead of the thickness given in property or in the shell definition.
