/INISHE/FAIL or /INISH3/FAIL
Block Format Keyword Describes the failure criteria for a shell.
| /INISHE/FAIL/unit_ID or /INISH3/FAIL/unit_ID | |||||||||
| shell_ID | Nlay | npg | nptt | lay_ID | fail_ID | Ifail_typ | Nvar | mat_ID | |
| V1 | etc | etc | |||||||
| VN | |||||||||
Definition
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| shell_ID | Element
identifier. (Integer) |
| Nlay | Number of
layers. (Integer) |
| npg | Number of surface
quadrature points.
(Integer) |
| nptt | Integration point number
through the thickness. It corresponds to the property definition of this element. (Integer) |
| lay_ID | Layer to initialize
| fail_ID | Failure criteria to
initialize identifier. (Integer) |
| Ifail_typ | Failure criteria number to
initialize. 2 (Integer) |
| Nvar | Number of failure criteria
variables to initialize. (Integer) |
| mat_ID | Material identifier to
| V1 | First failure criteria
variable value. (Integer) |
| VN | Nth
failure criteria variable (3 values per
line). (Integer) |
- If npg > 1, nptt > 1, and Nlay > 1, the lines with Real values have to be repeated for each integration point.
- Every failure model has a
Ifail_typ which is used to identify the failure model to
initialize for the element. Verify failure law to element type compatibility in
/FAIL.
- Keyword
- Ifail_typ
- /FAIL/ALTER
- 28
- /FAIL/BIQUAD
- 30
- /FAIL/CHANG
- 13
- /FAIL/COCKCROFT
- 34
- /FAIL/CONNECT
- 20
- /FAIL/EMC
- 27
- /FAIL/ENERGY
- 11
- /FAIL/FABRIC
- 31
- /FAIL/FLD
- 7
- /FAIL/FRACTAL_DMG
- 12
- /FAIL/GENE1
- 39
- /FAIL/GURSON
- 35
- /FAIL/HASHIN
- 14
- /FAIL/HC_DSSE
- 32
- /FAIL/HOFFMAN
- 46
- /FAIL/INIEVO
- 42
- /FAIL/JOHNSON
- 1
- /FAIL/LAD_DAMA
- 18
- /FAIL/MAXSTRAIN
- 47
- /FAIL/MULLINS_OR
- 33
- /FAIL/NXT
- 25
- /FAIL/ORTHBIQUAD
- 38
- /FAIL/ORTHENERG
- 48
- /FAIL/ORTHSTRAIN
- 24
- /FAIL/PUCK
- 16
- /FAIL/RTCL
- 40
- /FAIL/SAHRAEI
- 29
- /FAIL/SNCONNECT
- 26
- /FAIL/SPALLING
- 8
- /FAIL/SYAZWAN
- 43
- /FAIL/TAB1
- 23
- /FAIL/TAB2
- 41
- /FAIL/TBUTCHER
- 2
- /FAIL/TENSSTRAIN
- 10
- /FAIL/TSAIHILL
- 45
- /FAIL/TSAIWU
- 44
- /FAIL/USER1
- 4
- /FAIL/USER2
- 5
- /FAIL/USER3
- 6
- /FAIL/VISUAL
- 36
- /FAIL/WIERZBICKI
- 9
- /FAIL/WILKINS
- 3
