/FAIL/VISUAL
Block Format Keyword The purpose of this failure criteria is to record the maximum tensile 1st principal stress or maximum tensile 1st principal strain in a simulation. The maximum value of all the cycles in a simulation is used to compute the damage output.
The failure model is only for visualization and does not cause element failure. It is compatible with shells and solids elements and can be used with elastic, visco-elastic and elasto-plastic materials.
| /FAIL/VISUAL/mat_ID/unit_ID | |||||||||
| Type | C_min | C_max | F-coefficient | F-flag | Strdef | ||||
| fail_ID |
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| Type | Selector type.
(Integer) |
| C_min | Lower limit for stress or strain that defines
when the maximum value starts to be recorded.
Below this value Damage = 0.
Note: C_min ≥
0. Default = 0.0 (Real) |
or None |
| C_max | Maximum limit for stress or strain. Values larger
than this will have Damage =
1. Note: C_max ≥
0. (Real) |
or None |
| F-coefficient | Filter coefficient value. 1 If
F-Flag =1,
Exponential moving average.
(Real) |
| If
F-Flag = 2,
Cutoff frequency. Default = 0.0 (Real) |
| F-flag | Filter flag. 1
| Strdef | Strain measure definition used in failure criterion.
(Integer) |
| fail_ID | Failure criteria
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
kg mm ms
#- 1. MATERIALS:
/MAT/ELAST/2
steel
# RHO_I
7.85E-6 0
# E nu
210.00 .3
/FAIL/VISUAL/2
# TYPE C_MIN C_MAX F-COEFFICIENT F-FLAG Strdef
2 0.1 0.8 0 0
#enddata
- Filtering
option, F-Flag:
If F-flag=1, an exponential moving average filter is used for filtering the stress or strain. Assuming stress is being filtered.
Where,- Filtered stress
- The degree of weighting decrease, which is a constant smoothing factor between 0 and 1.
If F-Flag=2, a 4-Pole-Butterworth filter is used where the F-coefficient defines the cut-off frequency. This is the same filter used in /ACCEL.
- Damage is
output as:
Which means, is always 0 ≤ ≤ 1.
- Advanced math
in HyperView can be used to
calculate the maximum value:
- When maximum 1st principal strain TYPE=2 is recorded, replace stress in the previous equations with strain.
- For shell elements with /MAT/LAW1 (ELAST), only /PROP/TYPE1 (SHELL) N=1 is supported.
