/FAIL/JOHNSON
Block Format Keyword This failure model uses a nonlinear, plastic strain-based, failure criteria with linear damage accumulation. It describes the failure criteria by Johnson-Cook failure model.
| /FAIL/JOHNSON/mat_ID/unit_ID | |||||||||
| D1 | D2 | D3 | D4 | D5 | |||||
| Ifail_sh | Ifail_so | EPSFmin | Dadv | Ixfem | |||||
| FAILIP | |||||||||
| fail_ID |
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| D1 | 1st
parameter. (Real) |
| D2 | 2nd
parameter. (Real) |
| D3 | 3rd
parameter. (Real) |
| D4 | 4th
parameter. (Real) |
| D5 | 5th
parameter. (Real) |
| Reference strain
rate. (Real) |
| FAILIP | Number of failed integration points prior to element deletion
(only for integrated Beam). Default = 1 (Integer) |
| Ifail_sh | Shell failure flag. If Ixfem =0: failure - element deleted. If Ixfem =1: failure - element cracked. 2
(Integer) |
| Ifail_so | Solid failure flag.
(Integer) |
| EPSFmin | Lower plastic strain failure value. 5 (Real) |
| Dadv | Criterion for the crack
advancement (Only active if with Ixfem
=1). 4
(Real between 0 and 1) |
| Ixfem | XFEM flag (for
/PROP/SHELL,
/PROP/SH_SANDW, and
/PROP/TYPE51 properties only).
(Integer) |
| fail_ID | Failure criteria identifier. 3 (Integer, maximum 10 digits) |
Examples
In these two simple examples, strain rate and temperature are not considered. The stress-strain relationship could be simplified:
Example 1 (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
#- 1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9 0
# E Nu
210000 .3
# a b n EPS_p_max SIG_max0
270 450 .6 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/FAIL/JOHNSON/1/1
# D1 D2 D3 D4 D5
0.11 0.08 -1.5 0 0
# EPS_0 Ifail_sh Ifail_so EPSFmin Dadv Ixfem
1 1 1 1.2 0 0
# FAILIP
#enddata
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Example 2 (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
#- 1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9 0
# E Nu
210000 .3
270 450 .6 0 0
0 0 0 0 0 0
0 0 0 0
/FAIL/JOHNSON/1/1
# D1 D2 D3 D4 D5
0.11 0.08 -1.5 0 0
1 1 1 1.2 0 1
# FAILIP
#enddata
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- The parameters are used in
stress-strain relationship:
Where, ( is the stress triaxiality).
is computed for all material laws, as:
Where,- Tr
- Initial temperature
- Tmelt
- Melting temperature for materials LAW2 and LAW4
When /HEAT/MAT (with Iform =1) references this material model, the values of Tr and Tmelt defined in this card will be overwritten by the corresponding T0 and Tmelt defined in /HEAT/MAT.
- XFEM formulation
(Ixfem=1) is only compatible with BT Q4
(Ishell=1,
2, 3 or 4), and QEPH (Ishell=24) shell
elements. If XFEM is activated (Ixfem=1),
the failure criteria will lead to element cracking instead of element or layer
deletion.Two XFEM options are available: mono-layer and multi-layer. The XFEM option depends on the property type associated to the failure criterion applied to the material identifier:
- If /PROP/SHELL (TYPE1) is used, then mono-layer XFEM will be applied.
In this case, the whole element thickness is considered as a single layer. The failure criterion is calculated in each integration point, but only one single crack can appear in this element. This approach is compatible with all values of the shell flag (Ifail_sh=1 or 2). The crack direction is determined by the principal constraints in the last failed integration point.
- If /PROP/SH_SANDW (TYPE11) is used, then multi-layer XFEM will be applied.
In this case, each integration point over thickness is considered as a distinct layer. The failure criterion is calculated separately and the crack direction may be different in each layer. Crack direction in each layer will independently propagate from one element to another. Multi-layer XFEM is not compatible with Ifail_sh=1. Its value will be automatically set to Ifail_sh=2 in this case.- If /PROP/TYPE51 is used, then multi-layer XFEM
will be applied, and the separate cracks may appear in each layer
and propagate independently from one element to another. Thus, crack
directions and patterns will be different in each layer. The failure
criterion is calculated separately in each integration point and
crack will propagate when all the integration points fail within a
layer. Multi-layer XFEM is not compatible with
Ifail_sh=1.
Ifail_sh=2.Warning: Mono-layer and multi-layer XFEM formulations cannot be mixed in the same model, yet. The choice between them must be made for the whole model.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in the .sta file with /STATE/BRICK/FAIL option).
- Two different failure (rupture
or crack) are introduced in this failure model. The failure criteria is
calculated, as:
- Element rupture (Ixfem=0):
Element rupture (deleted) if D > 1
- Element crack (Ixfem=1):
Element cracked, if:
this element has no failed neighbors and D > 1, then in this case, new crack initialization in element.
this element has failed neighbors and D > Dadv, then in this case, crack advanced and Dadv is used for crack advancement. Dadv will be used if existing crack arrives to a boundary of an element.
Element deleted, if a second crack arrives to the same element.
Where,
Dadv should always be less than 1.
- It is recommended to use the EPSFmin parameter in order to deal with triaxiality levels higher than 1/3 (for example, plain-strain tension with a triaxiality level of 0.577).
