/FAIL/CHANG
Block Format Keyword Describes the Chang failure model.
| /FAIL/CHANG/mat_ID/unit_ID | |||||||||
| Ifail_sh | FAILIP | ||||||||
| fail_ID |
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| Longitudinal tensile
strength. Default = 1020 (Real) |
| Transverse tensile
| Shear strength. Default = 1020 (Real) |
| Longitudinal compressive
| Transverse compressive
| Shear scaling
factor. Default = 0 (Real) |
| Dynamic time relaxation.
7 Default = 1020 (Real) |
| Ifail_sh | Shell failure model flag.
(Integer) |
| FAILIP | Number of failed
integration points prior to solid deletion. Default = 1 (Integer) |
| fail_ID | Failure criteria identifier. 6 (Integer, maximum 10 digits) |
- This failure model is available for shell only.
- Where direction one is the fiber
direction. The failure criteria for fiber breakage is written as:Tensile fiber mode:
- For shells:
- For solids:
Compressive fiber mode:
- For shells:
- For matrix cracking, the failure
criterion is:Tensile matrix mode:
- For shells:
- For solids:
Compressive matrix mode:- For shells:
- For solids:
- For shells:
- If the damage parameter
, or
the stresses are decreased by using an
exponential function to avoid numerical instabilities. A relaxation technique is
used by decreasing the stress gradually:
With, and .
Where,- Time
- Start time of relaxation when the damage criteria is assumed
- Time of dynamic relaxation
- Stress at the beginning of damage
- The damage value,
D is
. The status for fracture is:
- Free, if
- Failure, if
with . This damage value shows with /ANIM/SHELL/DAMA.
- The fail_ID is used with /STATE/SHELL/FAIL and /INISHE/FAIL for shell. There is no default value. If the line is blank, a value will not be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick and with /STATE/SHELL/FAIL for shell).
- After the failure criterion is reached, the value determines a period of time when the stress in the failed element is gradually reduced to zero. When the stress reaches 1% of stress value at the start of failure, the element is deleted. This is necessary to avoid instabilities coming from a sudden element deletion and a failure “chain reaction” in the neighboring elements. Even if the failure criterion is reached, the default value of results in no element deletion. Therefore, it is recommended to define 10 times larger than the simulation time step.
- The different failure modes can be plotted using the option
/H3D/ELEM/FAILURE/ID=FAILID with the option
MODE(= I or ALL):
- MODE1: Failure index for tension in direction 1
- MODE2: Failure index for compression in direction 1
- MODE3: Failure index for tension in direction 2
- MODE4: Failure index for compression in direction 2
A global failure index (which correspond to the maximum between all modes) can be plotted using /H3D/ELEM/FAILURE/ID=FAILID without MODE option.
